Pushing Caliper Piston Back In
16 replies to this topic
#1 miniallsort
miniallsort
  • 4,723 posts
Posted 01 April 2012 - 06:13 PM
as title says what methods do people use to help push the caliper piston back in when changing discs and pads need help please my piston isn't budging grrr is there a tool u can buy to push it back
#2 C.P
C.P
  • 16 posts
Posted 01 April 2012 - 06:16 PM
Got some water pump pliers?
#3 Criptix
Criptix
  • 75 posts
Posted 01 April 2012 - 06:17 PM
i use a screw driver (a sturdy one) when i take the old pads out, while the old disk is still on. to push it back in.
#4 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 01 April 2012 - 06:19 PM
crowbar for me
#5 miniallsort
miniallsort
  • 4,723 posts
Posted 01 April 2012 - 06:31 PM
anyone used this before http://www.ebay.co.u...1#ht_1080wt_698
#6 miniman24
miniman24
  • 1,696 posts
Posted 01 April 2012 - 07:07 PM
I just use a big pair of grips to squeeze it back in :)
#7 miniallsort
miniallsort
  • 4,723 posts
Posted 02 April 2012 - 06:12 PM
Just. Bought the caliper piston tool will give it a go
#8 George929
George929
  • 556 posts
Posted 02 April 2012 - 06:18 PM
This wont work on a mini. it relies on the calliper being the sliding single piston type. a mini is a fixed caliper with two pistons
http://www.ebay.co.u...=item4ab1f47b97 this is the type of tool you need for a mini. The windback tools are meant for use on rear hand braked calipers. it allows the auto adjust for the handbrake to be wound back.
#9 jsiggee
jsiggee
  • 383 posts
Posted 02 April 2012 - 06:21 PM
Ive used a big pair of ajustable plyers before or a welding clamp. They both work well :D
#10 miniallsort
miniallsort
  • 4,723 posts
Posted 02 April 2012 - 06:23 PM
Many thanks for the reply I'm going to this tool or faling that c clamps
#11 George929
George929
  • 556 posts
Posted 02 April 2012 - 07:01 PM
sorry, but which tool are you going for
#12 Spitz
Spitz
  • 1,716 posts
Posted 02 April 2012 - 07:32 PM
That tool will work fine......it's pretty much a fancy C clamp.
I'd save your money.
...also...I leave the old pad in place while pushing the piston back....this way, if whatever tool you are using slips, you don't damage the edge of the piston.
#13 minimissionary
minimissionary
  • 999 posts
  • Local Club: Fylde Mini Club
Posted 02 April 2012 - 07:36 PM
C clamp and a piece of wood did it for me.
#14 miniyellowmini
miniyellowmini
  • 595 posts
Posted 02 April 2012 - 07:39 PM
Not changed any on the Mini yet but normally Vicegrips (mole grips) worked well for me in the past
#15 George929
George929
  • 556 posts
please explain how that tool will work on a mini caliper ??
this is how they work Posted Image
