I need a little advice on the best way to tackle the rust in the areas circled in red, it's really hard to get right in the corners behind those strengthening pieces. Should I just use wire brush attachments on a drill & grinder to get in there best as I can then cover in kurust before painting?
Also right in the corner where the three panels meet, in the area circled in green, I have a rust hole. Should I just chop the corner out & try to rebuild it with 3 different layers of metal like original or put in 1 shaped patch back in welded to the 3 different panels?
