Should I Use Redex?
Posted 04 April 2012 - 11:42 AM
I recently bought some Redex and was about to use it until someone suggested it might cause me problems! Anybody have any reasons why I shouldn't?
Cheers!
Posted 04 April 2012 - 12:03 PM
i have used it in the past not on a mini tho
i use something else in the mini
Posted 04 April 2012 - 12:07 PM
Posted 04 April 2012 - 12:11 PM
Posted 04 April 2012 - 12:18 PM
Posted 04 April 2012 - 01:30 PM
http://www.partinfo....jector MSDS.pdf
Section 4 shows the composition, the only active ingredient is 'Polyolefin alkylphenol alkylamine' which will have some detergency properties, everything else is just solvent and present in petrol anyway! It certainly wont do any damage to catalysts but whether the detergent is active or not is another question. Fuels these days all have detergents in them anyway to keep injectors clean, the more expensive fuels like Shell VPower etc have higher treat rates of detergents.
Posted 04 April 2012 - 01:54 PM
... as a car parts bloke once said to me when I was buying a bottle .. "Now, Andy, you're not going to put that in an engine that works , are you?!?!"
Posted 04 April 2012 - 04:28 PM
Posted 04 April 2012 - 10:07 PM
Posted 04 April 2012 - 10:14 PM
Presumably it'll just be trapped in the fuel filter, or burned and blasted out the back?Thanks for your opinions guys. I was thinking along the lines of...... whatever it cleans/removes in terms of carbon etc, has to go somewhere! Will that sludge then accumulate somewhere else?
Go to Unipart and get their Carb/Injector cleaner. Same stuff, but for about £2.50.
Posted 05 April 2012 - 08:29 AM
Posted 05 April 2012 - 08:39 AM
I love carb cleaner, Its the best stuff for cleaning engines etc
