Nitromors Removing Chrome On Alloys?
10 replies to this topic
#1 mt2man
mt2man
  • 149 posts
  • Local Club: PandSMOC
Posted 04 April 2012 - 10:12 PM
Just wondered if nitromors was man enough to remove the chrome from alloy wheels? I have tried sanding but its hardly even touching the chrome! Even with attachment on the drill.
Ideally i want to strip the chrome off completely and polish the rim and paint the centres, the same as the recent tutorial!
The chrome is peeling and looks naff, if needs be i will smooth them as much as possible and spray them and spray the rim in chrome effect paint but i think this will look naff and ideally want to do it properly!
Thanks Jack
#2 charie t
charie t
  • 3,153 posts
Posted 04 April 2012 - 10:13 PM
no, nitromors won't even touch it. Chrome is not paint
Blasting is cheapest bet
or having the chrome removed by a plating company, may be rather pricey though
Edited by charie t, 04 April 2012 - 10:14 PM.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,057 posts
  • Name: Neil
Nitromoors wont touch it. Ideally you need to take the wheels to an electro platers to get the chrome removed.
#4 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 04 April 2012 - 10:17 PM
As above. Chrome is a plating, rather than 'stuck' on, like paint.
#5 mt2man
mt2man
  • 149 posts
Posted 05 April 2012 - 10:44 AM
Bugger thought that might be the case! Okay thanks guys!
Atleast i didnt waste money buying some paint stripper then! haha
#6 mt2man
mt2man
  • 149 posts
Posted 05 April 2012 - 10:46 AM
Do you think sanding the peeling areas as much as possible to try and feather out the effected areas and then spray the whole wheel in high build primer and then sand it flat will make it less noticeable?!
I cant really afford to take the tyres off, get them sandblasted, repainted and then tyres put back on :/ Its never going to be a show car just want to tidy them up a little bit.
#7 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 April 2012 - 10:59 AM
You are sure the wheels are chromed and not polished?
#8 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 05 April 2012 - 11:17 AM
Sandblasting won't work.
As Sonikk said, you need to take them to an eloctroplaters..
They're PLATED
#9 pdaykin
pdaykin
  • 587 posts
Posted 05 April 2012 - 04:20 PM
As noted above, if the plating is generally sound sand blasting will not remove it.
#10 sonikk4
sonikk4
  • 16,057 posts
  • Name: Neil
Posted 05 April 2012 - 07:18 PM
Chrome is extremely hard and to that point trying to sand it would be pointless. Also once it starts to peel off the rest is sure to follow i'm afraid. The only thing you can do is to grin and bear it for the moment until you can save enough money to sort it out properly
#11 mt2man
mt2man
  • 149 posts
Posted 05 April 2012 - 07:56 PM
Thought that maybe the case :/ i shall just make them as pretty as i can with what i have in the garage and just get them done properly once my tyres need replacing!
Thanks guys!
