Where To Put Spreader Plates
Posted 07 April 2012 - 09:00 AM
fitting my roll cage and am wondering which side to put the spreader plates, under the foot or on the other side of the body?
also do i have to weld them in because ive ran out of wire and am not the best at a solid weld.
cheers
brad.
Posted 07 April 2012 - 09:08 AM
For competition use, weld them inside the car.
For road use it's OK to use them as a spreader plate on the outside of the car.
Posted 07 April 2012 - 09:16 AM
Posted 07 April 2012 - 09:18 AM
Are your rear bins still in place?
Posted 07 April 2012 - 09:21 AM
Posted 07 April 2012 - 09:32 AM
Matt, remember most modern cars arent constructed like a mini, as such even the idea of using the speaders on the outside wouldnt be possible. Some cars even have to use captivated nuts due to the sections they sit on.
Posted 07 April 2012 - 09:38 AM
Posted 07 April 2012 - 10:13 AM
Posted 07 April 2012 - 11:22 AM
plates on the outside support the frame as a pulling force, plates on the inside support the frame as a pushing force. Cages are designed to prevent crushing normallyI never really understood the benefit of welding the plates inside over welding them on the outside, infact I'd think they'd be better on the outside really...but hey-ho. Regulations is regulations!
Edited by charie t, 07 April 2012 - 11:30 AM.
Posted 28 April 2012 - 12:34 PM
That's all well and good, but the safety devices "spreader" plates are the exact same size as the plate welded to the bottom of the roll cage to form the foot of the cage. My point is, that if you weld them onto the inside of the arch, then what exactly are they doing?
Posted 28 April 2012 - 01:55 PM
Posted 28 April 2012 - 08:00 PM
Edited by icklemini, 28 April 2012 - 08:01 PM.
Posted 29 April 2012 - 04:45 AM
If you are going to be installing a cage, then you better be installing it absolutely as safely as possible. As well as this, don't expect to carry passengers in the rear, and you better have minimum a 4 point harness and bucket seats. Cages are only safer when you have the equipment to go with them. I would never drive on the street with passengers in the rear and a cage; wayyy too easy for them to hit their head on it, which is EXTREMELY dangerous in a crash, even at low speeds.
Also: Cages should be properly padded. Harness should be attached to a harness bar set at the correct angle to give proper support; I would never trust a 5 point attached in the rear to seat belt holders, let alone anything attached into the thin sheet metal of the shell.
Posted 29 April 2012 - 10:24 AM
