Best Fuel Tank for Turbocharging?
Posted 28 February 2006 - 12:12 PM
I'm in the process of sourcing a fuel tank for a turbo mini and I'd like to know the differences between SPI and MPI tanks.
From searching the forum, MPI tanks seem to be the favourite choice, but I'm assuming it's possible to use an SPI tank?
Also what sort of price do these tend to go for and how available are they?
Cheers,
Mart
Posted 28 February 2006 - 02:29 PM
price wise anything from £40 upwards really...
Posted 28 February 2006 - 03:19 PM
I'm not thinking of going too lary with the boost but it might be worth safeguarding for the future and go for the MPi tank.
Which mini's were MPi? Are these tanks fairly easy to get hold of?
Posted 28 February 2006 - 10:39 PM
Phil.
Posted 28 February 2006 - 11:38 PM
Posted 01 March 2006 - 08:35 AM
Phil.
Posted 01 March 2006 - 06:27 PM
Simple enough to do, plus your save yaself £50-60!!
Posted 01 March 2006 - 08:15 PM
Posted 01 March 2006 - 08:55 PM
Posted 01 March 2006 - 10:47 PM
I had thought about doing this - but it just seemed easier and neater to use an injection tank.or you could always modify your existing tank...
Whats the best/neatest method of plumbing in a fuel return line to the tank? I'm assuming you can buy some sort of spigot which secures with a nut and a seal......
........as I don't fancy welding the tank.
Posted 01 March 2006 - 11:42 PM
Posted 02 March 2006 - 11:30 AM
97 onwards Mpi
Posted 02 March 2006 - 11:43 AM
i'm not running a return into my tank. the return feed from my regulator is fed back down and round and T pieced into the fuel feed between the tank and the pump. There are quite a lot of people doing it this way now and as far as i know no-one else has had any ill effects from it.
Thats what I will be doing..
Simpler then welding in a return.
Posted 02 March 2006 - 04:49 PM
To point out for safetys sake, that plumbing the return back to the pump feed line is only satisfactory on a standard tank with an external pump. Do not try this with the injection tank as the pump is in the tank itself. Plumbing the return in like this on The injection tank will over pressurise the carb sqirting fuel everywhere. Not that it will happen, but there are some people that just dont know what they are doing and need telling, And not that you are like that, but it needs to be said
Just to clear that up before some one tries it
Posted 02 March 2006 - 07:15 PM
1. Modified (with return line) non-injection petrol tank with external fuel pump.
2. Standard SPI tank (which has pump in tank).
3. Standard MPI tank (which has pump in tank).
Of all of these the injection tank seems the neatest solution - no external pump to mount/plumb in and no return line fitting to add to the tank.
IMO its seems a bit gash to t-piece back into the fuel supply line near the tank - I'm sure I 've read somewhere that the return should be as high in the tank as possible?
Not sure on the reasons for this though.
