Differential Shimming
Posted 09 April 2012 - 04:47 PM
I put the diff in place and push it to the right (clutch side) and then i place the casing on and tighten that down. Then i put the output plate on the right hand side with a gasket and nip it up, next i am putting the left hand plate on without a gasket and nipping that up but i get no gap at all to get a feeler gauge in.
Am i going wrong somewhere? When i removed the old diff it came with 0.12thou of shims already in.
Nick
Posted 09 April 2012 - 04:49 PM
Posted 09 April 2012 - 05:12 PM
Should it just be finger tight?
I am just worried i wont get this right.
Posted 09 April 2012 - 05:17 PM
The casing shouldn't be fully tight for this no, it needs to be in the right position for the side plates to align but not fully tight. If the diff can't move, you can't shim it. Also if it can't move and you fully torque the side plates with it in the wrong position you can deform the plates.
Posted 09 April 2012 - 06:05 PM
Posted 09 April 2012 - 07:29 PM
Posted 09 April 2012 - 07:36 PM
http://www.theminifo...ng/page__st__15
Posted 09 April 2012 - 08:12 PM
Posted 10 April 2012 - 04:12 PM
so if i take the gasket is a 0.003 like andys is, i have 0.012" of shims so the gasket will make up the extra 0.003" i need. correct?
confusing me haha
Posted 10 April 2012 - 04:15 PM
Posted 10 April 2012 - 04:31 PM
Posted 10 April 2012 - 04:47 PM
Posted 10 April 2012 - 09:28 PM
Posted 10 April 2012 - 10:01 PM
Use of the feeler gauges gives you the compressed thickness, which is usually what matters.
Posted 11 April 2012 - 05:31 AM
Even after watching guessworks video......brain fart.
I think I put too many shims in mine last year, as I get some toque steeer now that I didn't before ( or maybe that means too few?? )
