Something Catching On The Timing Chain Cover?
9 replies to this topic
#1 oltonlad
oltonlad
  • 2,401 posts
Posted 09 April 2012 - 06:59 PM
i have nearly finished my 1098 engine build but as i turn the engine over by hand it sounds as if there is something catching on the timing chain cover, i have fitted a duplex kit and its all fine when the cover is off, it sounds very much like the chain rubbing on something when the cover is fitted.....i did however fit the metal washer shim thing (the one with the "F" stamped on it).....on the end of the crank behind the timing cover, should this still be fitted with the duplex kit as i'm sure that i never fitted one on my last engine (which also had a duplex kit).
cheers in advance.
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 09 April 2012 - 07:05 PM
have you knocked out the cover, you have to knock out the cover to stop the chain fouling, I forget which point, but if you remove cover should be able see where its rubbed.
#3 oltonlad
oltonlad
  • 2,401 posts
Posted 09 April 2012 - 07:09 PM
oh....ok, i didn't realise that the cover had to be modified to clear the chain, i will give it a good few turns then so that it gives it a chance to mark the inside of the cover,
thanks.
#4 oltonlad
oltonlad
  • 2,401 posts
Posted 09 April 2012 - 07:10 PM
unless anyone knows where the chain is likely to rub so that i can definetely sort it out 1st time round...........
#5 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 09 April 2012 - 07:25 PM
Did you remove enough of the inside of the timing cover? there is also a small lump that you have to bash flat..here is a picture of the one I did for my engine..
you can see the bit I had to bash flat at about 10o'clock next to the oil seal..
Edited by AndyMiniMad., 09 April 2012 - 07:26 PM.
#6 oltonlad
oltonlad
  • 2,401 posts
Posted 09 April 2012 - 07:36 PM
it must be the bit next to the oil seal that is catching the chain, its a small bore engine cover so there's no breather on it....so it cant be that
cheers for that, i will have a look tomorrow.
#7 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 09 April 2012 - 08:13 PM
I seem to recall that one (or two) of the screws that hold the front plate need to be changed for coutersunk ones... otherwise the wider duplux chain will catch on them.
#8 jaydee
jaydee
  • 8,565 posts
Posted 09 April 2012 - 08:23 PM
My small bore has breather on the timing chain cover..
#9 oltonlad
oltonlad
  • 2,401 posts
Posted 09 April 2012 - 08:32 PM
it must have a 1275 timing cover on it then............. :proud:
#10 oltonlad
oltonlad
  • 2,401 posts
Posted 09 April 2012 - 08:34 PM
yeah, i have already countersunk the backplate and fitted 2 torx countersink screws, it doesent make any noise when the cover is off so it must be what andyminimad suggested earlier....
cheers.
