Reconditioned 12G940 Cylinder Head Modified
6 replies to this topic
#1 andymini12
andymini12
  • 812 posts
Posted 09 April 2012 - 11:25 PM
Hi,
For sale is a reconditioned unleaded 1275 cylinder head.
Hardened exhaust valve seats for unleaded petrol, valve sizes are 33.3mm inlet and 29.4mm exhaust, head has bead bead blasted and washed, head gasket has been surface ground to retain best possible flatness for gasket reliability, rocker face has been ground to clean it up, the inlet/exhaust face has been milled flat, all threads have been re-tapped, valve have been cleaned and relapped into the head, valves has also been modified (Vizard style) by giving a 30 degree back chamfer to aid air flow, combustion chambers have been de-shrouded around the exhaust and inlet valves to aid air flow, double valve springs, pressed rockers (highest standard ratio about 1.27), brand new valve stems on all valves and valve guides, no water bypass, painted red. -
£150, will find out how much postage is.
Maidstone Kent
Any questions please ask.
Can get more photo's if wanted.
#2 andymini12
andymini12
  • 812 posts
Posted 11 April 2012 - 11:13 AM
Can now do £150 posted.
#3 beansontoast
beansontoast
  • 25 posts
Posted 19 April 2012 - 07:28 PM
i did post on this but my posts disapeared.
Anyway ill take this off your hands but.... i can only take it after payday which around 22nd?
Let me know if this is ok.
Im only down the road too in dartford so if you could pm a postcode and ill pop round with the cash when ive been paid.
cheers
#4 andymini12
andymini12
  • 812 posts
Posted 19 April 2012 - 08:56 PM
I have PM'ed you!
#5 Nick04
Nick04
  • 225 posts
Posted 21 April 2012 - 07:46 AM
Does it have a bypass hose??
#6 edward92
edward92
    Starting My Mini Up
  • 4 posts
Posted 29 April 2012 - 10:10 PM
Is this still for sale?
#7 andymini12
andymini12
  • 812 posts
Posted 29 April 2012 - 10:22 PM
Sorry this is now sold. Cheers
