Early Type Valve Collet Clips
6 replies to this topic
#1 Leekr89
Leekr89
  • 104 posts
  • Local Club: CV1 MINIS
Posted 12 April 2012 - 09:36 PM
i have a reconditioned 12g202 head and it appears to be missing the small retaining r type clips that hold the 2 collets together, anybody know where i can get hold of some of these? tried a couple of mini places but no luck :(
#2 Ivor Badger
Ivor Badger
  • 846 posts
Posted 12 April 2012 - 09:49 PM
The only reason I could ever see for them was for initial assembly. so there is no point in fitting them after the head is back together.
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 12 April 2012 - 10:02 PM
somerford have them listed,
http://www.somerford...roducts_id=6755
#4 tiger99
tiger99
  • 8,584 posts
Posted 12 April 2012 - 10:10 PM
Provided your valve springs are in good order you definitely do not need those clips, as the colletts will never become unloaded, even at peak revs. With old valve springs, you may get valve bounce at high revs, and that may theoretically cause the collets to be ejected, dropping valves down cylinders, with the engine inevitably being written off.
A very good reason, along with performance, economy and valve seat life, for fitting new valve springs every time you do a head overhaul. They are not the most expensive of parts.
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 13 April 2012 - 08:13 AM
I have a load somewhere, give me a shout if you get stuck.
#6 Leekr89
Leekr89
  • 104 posts
Posted 13 April 2012 - 11:04 PM
Thanks for the help guys will have to give somerford a shout, cant afford dropping a valve as its a freshly rebored engine, its my girlfriends engine and she doesnt want it going pop in a hurry!
#7 tiger99
tiger99
  • 8,584 posts
Posted 13 April 2012 - 11:15 PM
You will not drop a valve unless the valve springs are inadequate. Presumably you did replace them on an overhauled engine?
