Replacing Leaking Bottom Hose
Posted 13 April 2012 - 03:14 PM
Am I right in thinking I need to do something like this:
1. Detach hose from bottom of radiator and leave to drain
2. Drain cylinder head - is this necessary? Suppose I might as well refresh the coolant while I'm at it
3. Detach bottom rad hose from heater hose and water pump - do I need to remove the radiator to do this?
4. Remove and replace bypass hose. I'm going with the collapsible type for now because I'm lazy
5. Attach new rad hose
6. Fill up with DI water & antifreeze - I usually do a cocktail of 50/50 measures
7. Let it run and warm up for a bit. Kill engine, let it cool, top up if necessary.
Sound about right? '91 Mini Mayfair 998 by the way.
Posted 13 April 2012 - 04:17 PM
As for the bypass hose, don't skimp, I was going through a concertina hose every couple of weeks, fitted a proper hose and it's been fine for the last 7 years...
Posted 13 April 2012 - 06:20 PM
Posted 13 April 2012 - 06:27 PM
Posted 13 April 2012 - 10:29 PM
Except for early models, it really is easiest to take the radiator out to fit the bottom hose, and supremely easy to take the water pump out to change the bypass hose for the proper type. I had to do that at the side of the road once, because a 2 week old convoluted bypass hose had burst. I shortened one of the heater hoses slightly to obtain a suitable piece of hose to replace it, and that lasted upwards of 60,000 miles, until the engine was worn out.
Posted 13 April 2012 - 10:31 PM
I do what Beige says, as the circlip at the rad side of the bottom hose is usually much rustier than the one on the water pump side - I had to cut mine off with a hacksaw when replacing my bottom hose a few weeks ago! Most of the water drains out well this way too. You may as well fit the proper bypass hose while the rads off, its a 10 min job to whip the water pump off, fit the new pipe and a new gasket and re-assemble :)
Getting hold of a water pump gasket from your local autostore is a pain in the ass though as me and my mate found out doing his bypass hose a few weeks ago, ended up buying a new pump just for the gasket!
Posted 13 April 2012 - 11:36 PM
Posted 14 April 2012 - 12:08 AM
Posted 19 May 2012 - 12:31 PM
