Right, i fully restored it in September 2010 i've got bills adding up to over £3000 and thats with out the body and paint work and I bet you would never see another mini with the same colours.
I rebuilt the engine to a high quality standard, it didnt need doing as it only done 28k miles but i did it any way. I replaced the big end barings, thrush washers, piston rings, re-grinded all the galves, replaced the single valve springs with double valve springs, cam followers, duplex timing chain and all gaskets and seals. While i was doing it i replaced the cam with a piper 276 high lift cam with the intensions of putting a race head on, so its all ready to just swap the heads over, it also had a new clutch. It was tuned on the rolling road and had 54.4 BHP / 6047 1min (82mph) 55.4lbft / 4211 1min
Stage one kit
All new spax with adjusta ride
Brand new clutch and brake master cylinders
Fronts converted to disc's which I rebuilt with all knew bearings, pistons, seals, bleed nipples discs and pads
All new rear brake set up with new brake fluid pipes and bearings
I fully repaired and painted the mini myself as its what i do for a living at Fords. The only major bit of rust was on the rear boot hinge pannel which i cut out and replaced with a new pannel. Ive underseald the whole underside.
Ive fitted some recaros recliners which i had to make a set of tilt and slide subframes for so the back is still accessable. I payed for some dimond stiched door cards and a parcelshelf cover. I made a dash out of mdf and covered it in the same material as the rest of the intiorer.
Its wearing a set of 13x7 deep dish mini lights with four good tyres.
It has a slight bit of damage on the front off-side where soe one caught the wheel arch
It dosnt have a MOT or Tax as its been of the road for about 6 months.
<a href="http://s801.photobuc...nt=IMAG0037.jpg" target="_blank"><img src="http://i801.photobuc...ct/IMAG0037.jpg" border="0" alt="Photobucket"></a>
heres a link to my photobucket which has pictures of the whole restoration as there is far to many pictures to post them all up
Car
http://s801.photobuc...ject/?start=all
Engine
http://s801.photobuc...../Mini Engine/
If you want me to be honest I dont know how much i want for it so im just going to put it down for offers. If you have any questions please ask. Also i may be able to get it MOT'ed and maybe taxed at the buyers choice.
This is an ideal first car as this was my first car
Im looking for how much ive spent on it receipts wise which is £3000 and take into consideration that there are things that dont have bills like the bodywork and paint job
Edited by JoneseyBoy, 25 April 2012 - 10:11 PM.
