Replacing Rear Quarter Panel
26 replies to this topic
#1 Rally85
Rally85
  • 42 posts
Posted 25 April 2012 - 11:37 AM
Hey all
As the title say aim replacing the rear quarter panel. I am using a non genuine panel AMD the curves on the corners of the window are not lining up. Has anyone ales had this problem? Any advice on how to fix it. Would I have the same issue with a genuine panel?
Cheers in advance.
#2 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 25 April 2012 - 04:26 PM
bin it and use a genuine panel
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 25 April 2012 - 06:51 PM
oh well you have some tin plate, go get the proper panel for a proper job
#4 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 25 April 2012 - 07:06 PM
which non-gen panel did you buy? i replaced both of mine using non gen ones. Shifty said to me, ensure you buy the pannels which go up the pillers slightly, the ones which just go to below the window are a bad fit.
#5 mini_in_progress
mini_in_progress
  • 641 posts
Posted 25 April 2012 - 07:12 PM
yea i found this out the hard way, you will have to ether cut the top off the panel off and leave the crease in the car panel or weld the panel under the original at the top part below window..... mine was a nightmare to get okish
#6 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 01 February 2013 - 12:41 PM
I am considering replacing both my rear quarters in order to speed up the rebuild.
Can anyone recommend a good quality non-Heritage panel? Minispares have some for £95 inc VAT are these any good?
http://www.minispare...px|Back to shop
Also can anybody point me to a good thread with a replacement with lots of pics so I avoid any pitfalls?
Jason
#7 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 01 February 2013 - 03:06 PM
http://www.ebay.co.u...=item2a0fc7d016
Has anyone fitted the Magnum quarters? Only £30.
#8 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,144 posts
  • Name: Sean
Posted 01 February 2013 - 04:32 PM
Yes, as mini93 says there are 2 types(that I know of), one type has the cut point just above the swage line on the body and the other extends up into the pillars. The first type are utterly useless and I wouldn't beg one!!
I bought a magnum one(with the pillars at the weekend to use on my new project. Looks ok, but won't be fitting it for a while.
#9 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 01 February 2013 - 04:50 PM
The Magnum ones are massively cheaper but need to know if they fit well or if they only need minor adjustment?
If they need hours of work then that would rule them out.
#10 mini93
mini93
  • 8,615 posts
Posted 01 February 2013 - 06:01 PM
My magnum pannels required a bit of jiggery pokery.
All panels are likely to require a bit of a fettle, i wouoldnt say it was hours more than a regular panels would require.
#11 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 01 February 2013 - 06:42 PM
What did it need to make it fit? Any pics?
#12 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,052 posts
  • Name: Neil
Posted 01 February 2013 - 06:50 PM
I am in the process of fitting Magnum quarters to The Red One so have a look at that thread. I have had to cut around the front pillar section to get it to align.
#13 mini93
mini93
  • 8,615 posts
Posted 01 February 2013 - 06:52 PM
Access to alot of clamps etc will make things easier id guess. I didnt have that many so had to do with what i had.
Spot welder if you can get hold of one, plug welding everything was a bit of a pain.
Is the only picture i have really and its not very good!
I layed the panel up against the panel i was removing, under cut and took it back to the desired point.
I dont really know how straight my car is due to it being an ex-rally car, but it just needed a slight ease by hand in places.
Lined it upto the seam edge and just needed a bit of a hammer to the correct position on the door edge.
My driver side didnt require much fettling and fit the door piller edge fine
#14 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 01 February 2013 - 07:27 PM
I have seen yours on the Red One thread. It does not look too bad; just a couple of cuts.
If that is all it is then I will go for the Magnum panels as they are so cheap. Who is the best seller?
#15 Shifty
Shifty
  • 13,144 posts
  • Name: Sean
Posted 01 February 2013 - 07:28 PM
Just buy the ones with the part pillar, the others are utter crap. I paid £27 for one from old skool minis at Bingley.
