Twin Hs2 Needle Help
12 replies to this topic
#1 DanParsons
DanParsons
  • 135 posts
Posted 26 April 2012 - 05:31 PM
Hi guys and gals, I'm using a standard 998 A+ engine with LCB Manifold and system, any suggestions with needles + springs to use on/in twin hs2 1 1/4" used with K&N cone filters?
Cheers Dan
#2 tommy13
tommy13
  • 878 posts
Posted 26 April 2012 - 08:36 PM
According to this either GY or M
http://www.7ent.com/...tor-needle.html
#3 DanParsons
DanParsons
  • 135 posts
Posted 28 April 2012 - 08:13 PM
cheers!
#4 Dusky
Dusky
  • 5,322 posts
Posted 06 August 2014 - 02:48 PM
What needle do you use now? ;)
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 August 2014 - 04:20 PM
I suspect the GY will be a bit rich as this was the standard needle in the 998 55bhp Cooper, and the M needles were standard in the 1275 S, trial and error with some plug readings on the GYs and see how they work out and then back to the needle charts if it is to rich.
#6 Dusky
Dusky
  • 5,322 posts
Posted 06 August 2014 - 04:34 PM
Do you think a cooper spec with k&n cone filters will work with the GY needle?
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 August 2014 - 05:26 PM
@Dusky I was replingy to the OP standard 998, if you had a engine to exact Cooper spec and fitted cone filters I suspect it would be weak somewhere in the range
#8 Dusky
Dusky
  • 5,322 posts
Posted 06 August 2014 - 05:28 PM
Got k&N+ stubstacks, but my cylidner head is standard valve ported :P
So Im doubtin between M and GY because I don't know howmuch te valve size will affect the mixture :l
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 August 2014 - 08:27 PM
Flow will be affected so GY I'd try as a starter
#10 Dusky
Dusky
  • 5,322 posts
Posted 06 August 2014 - 08:29 PM
Ill be ordering tonight/tomorrow.
1 more question ( and then I let you go to bed lol ) blue springs or red springs? :P
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 August 2014 - 08:35 PM
Standard springs for the 1 1/4s I'd say, which from memory are the blue ??
#12 Dusky
Dusky
  • 5,322 posts
Posted 06 August 2014 - 08:41 PM
Awesome, should be blues in it then I think? Can I test it? ( they look grey :P )
#13 Dusky
Dusky
  • 5,322 posts
Posted 07 August 2014 - 09:26 AM
Minispares advices me the E3 with red springs, I'll try my current needles with red springs first I think , E3 looks quite similar...
