Wanting More Power! Advice Please People
Posted 27 April 2012 - 08:42 PM
Engine spec
A+ engine
Longman race head 36mm inlet and 29mm exhaust valves and a compresion ratio of 10.9-1
Megajolt 3D mappable ignition with coil, trigger wheel, censors, wiring loom and edis unit
1293 AE slipper pistons and rebore to match
ARP con rod bolts
V-max skart lightened balanced con-rods,
reground lightened balanced crank.
lightened flywheel new cluch
Kent 286 megadyne cam, new followers and double valve springs
Cam belt drive conversion
Minispares 1-3 roller rocker
facet electric fuel pump
vizard'd hif44 carb
maniflow stage 2 lcb
High torque starter motor
All new gaskets and seals
New cam, big end and crank shells and engine bearings
Adjustable oil pressure valve
New high volume oil pump
all new bolts ARP bolts where necessary, stainless steel elsewhere.
Minispeed recon gearbox 3.44 final drive
mini spares xpin diff
its currently producing 81bhp at the wheels and 93atf,
what do you reccommend for my next mods?
i have been looking at specialist components 7port kit. does anyone here have one and would you reccommend one?
im just after advice on where i can gain more power, is the cam on its limit and how many bhp will a hiff44 be suitable for? cheers
Posted 27 April 2012 - 09:03 PM
Edited by jaydee, 27 April 2012 - 09:03 PM.
Posted 27 April 2012 - 09:07 PM
Posted 27 April 2012 - 09:12 PM
Posted 27 April 2012 - 09:15 PM
CR 12.1 and it will fly
Edited by jaydee, 27 April 2012 - 09:17 PM.
Posted 27 April 2012 - 09:17 PM
Posted 27 April 2012 - 09:19 PM
Posted 27 April 2012 - 09:22 PM
Posted 27 April 2012 - 09:23 PM
Posted 27 April 2012 - 09:25 PM
i had 11-1 in one of my road race engines
using the vizard SPV4 cam
Posted 27 April 2012 - 09:30 PM
Posted 27 April 2012 - 09:32 PM
Posted 27 April 2012 - 09:38 PM
Posted 27 April 2012 - 09:55 PM
What do you use the car for?
If you go for much more power you'll be needing to use a lot of revs all the time which will mean frequent re-building.
