Sure you have enough petrol in it... haha
Haha, im not that tight
I had a similar sounding problem. When I went up hills the car wouldnt run perfectly and as soon as I grabed 4th it would just judder and loose most power. Turned out to be the valve clearences set too tight. It might not be what you have but its worth looking into before you replace anything.
I will have a look at that this morning, thanks
As for what to replace when you get to that point... look along the fuel line from the tank all the way to the carbs and replace any fuel filters you find. Also replace your air filter.
I will try the clearences first, then fuel pump and if the worst comes to the worst i will replace the fuel lines... Cheers!
I had this issue with mine, ran fine on the flat, but as soon as I started climbing hills it would just die. Ended up having to take massive run-ups!
Replaced my fuel pump and it solved the problem. Don't forget to replace the gasket if you do end up changing the pump! :)
I have a feeling it is the fuel pump, but i will mess around with the clearances and give it a run, if that doesn't work then i will replace the pump (which should hopefully work) Cheers
