Rust Inhibitor
7 replies to this topic
#1 clinchy
clinchy
  • 73 posts
Posted 28 April 2012 - 10:00 AM
hey people,
i have two litres of liquid rust inbihitor and im wondering if after having my shell shot blasted, rather then painting it straight away then doing all the welding, can i just spray it with the inhibitor to keep the rust at bay as its going to be sitting around for a while.
cheers.
luke.
#2 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 28 April 2012 - 11:06 AM
Just sounds silly to me. You want to get it in etch primer ASAP after blasting. Preferebly there if they provide the service
#3 Sam Walters
Sam Walters
  • 2,765 posts
Posted 28 April 2012 - 11:13 AM
Have it epoxy primered with lechler epoxy at the blasting place.
You can then leave it under a sheet and come back to it in 10 years time.
#4 1964Woody
1964Woody
  • 201 posts
Posted 28 April 2012 - 05:50 PM
=1 for epoxy primer. My Countryman shell was sandblasted and epoxy primered years ago by the guy I bought it from. Then he just let it sit in his garage. There is no new rust, no bleed through anywhere in the areas that were primered (he did not blast or primer the panels that needed to be replaced and they continued to rust).
#5 clinchy
clinchy
  • 73 posts
Posted 29 April 2012 - 09:32 PM
ok, is it worth coating it in inhibitor before priming it?
#6 mini_in_progress
mini_in_progress
  • 641 posts
Posted 30 April 2012 - 01:04 PM
when i worked at acid dipping place ihibitor is only really used with the jetwash so it dont rust while cleaning it off if you were to then leave it outside for a day and it rained it would form surface rust so really no need for using it imo
#7 Sam Walters
Sam Walters
  • 2,765 posts
Posted 30 April 2012 - 01:21 PM
If you use epoxy and get down to clean metal you wont need a rust inhibitor.
#8 clinchy
clinchy
  • 73 posts
Posted 05 May 2012 - 07:16 PM
ok cool, ordered my primer and a new gun yesturday so just waiting for the guy to come blast her.
cheers for the replys guys.
