Fitting Rear Shocker Top Nut. Help!
5 replies to this topic
#1 MarkMcc
MarkMcc
  • 82 posts
Posted 30 April 2012 - 06:40 AM
HI there,
I have lowered Gaz adjustables fitted to my clubman.
I had to remove one to get to a mangled rusty nut at the rear of the backplate.
Only problem is that now I'm trying to refit the strut, I just can't get the upper top rubber (and the one below the mount) in the boot to compress enough to allow the various washers to fit asnd the nut to bite into the thread.
I have backed off the hi-los so there is no problem poking the top of the damper through the mount hole, but it just compresses when I try and push it up.
When I did this first, earlier this year, I had help but I just cant' remember how we did it!
There's bound to be some sort of trick to this, but I was just too tired last night to be inventive enough!
Please share your collective wisdom.
MArk
#2 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 30 April 2012 - 06:47 AM
I always fit the top nut first, on any car, as when you are trying to put the bottom bolt back on, you can put the wheel back on, and lower the car to the floor and then put the bolt in easier
#3 maccers
maccers
  • 1,873 posts
  • Local Club: LSMOC
Posted 30 April 2012 - 07:20 AM
You can use a jack to lift and compress the shock until it pushes more of the thread into the boot area past the rubber bushes. If the very top of the unit is badly rounded off with numerous mole grips being used to tighten it up, try a spanner under the wheel arch right at the top, my old Gaz shocks had a big blob of weld there and fitted into a 14 or 15 spanner nicely.
#4 MarkMcc
MarkMcc
  • 82 posts
Posted 30 April 2012 - 07:46 AM
Thanks for the quick replies guys!
Not just me up early and thinking about minis on a Monday morning!
I'll give these suggestions a go.
#5 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 30 April 2012 - 07:48 AM
I got my neighbour to stand on the boot lip and because hes a big lad the nut flew on!!!
#6 MarkMcc
MarkMcc
  • 82 posts
Posted 30 April 2012 - 08:34 AM
Good idea! Can you send him round?
