Hey, I have a 1996 mini sidewalk. ive just had it back from the spray shop, it hasnt been driven in nearly 3 weeks. It started first time no problem. but when i went to pull off, it wouldnt go into first gear and i had to ram it in, but since ive had the car ive always had to double cutch second gear. Please help I need to get it working asap. Bank Holiday weekend :)
thanks
Adam
Wont Go Into First Gear Sometimes And I Have To Double Clutch Into Second Help!
aroynon
, May 04 2012 03:01 PM
7 replies to this topic
Posted 04 May 2012 - 03:01 PM
Posted 04 May 2012 - 03:40 PM
well the second gear issue is prob due to the synchro is gone in the box.
Posted 04 May 2012 - 04:11 PM
Sounds like you may need to pull the engine out and inspect the gearbox. As above sounds like you need new synchros.
Posted 04 May 2012 - 04:12 PM
You can shuffle the gears by letting go of the clutch then stepping on it again and try putting it in first then.
Repeat till you can put it in gear.
Also, it's easier to put it into second first then shifting into first, if you find it difficult to go from neutral to first.
Your gearbox is just showing wear, I personally wouldn't worry about it till you can afford a gearbox rebuild.
Edited by minimarco, 04 May 2012 - 05:42 PM.
Posted 04 May 2012 - 04:48 PM
My first takes ages to spin up to speed if Im going anything more than 10, so I have to wait till Ive braked down to the right speed to slide it in, always been like that, hasnt got worse in 20K of me driving the car. Cant afford a rebuild so Ive just got used to it!
Posted 05 May 2012 - 07:50 PM
If i was you just give the clutch a good bleed first. >it can be this if you're pumping the cluctch first and then it goes in smoothly after. Report back if it works
Posted 05 May 2012 - 08:41 PM
my first impression would be to bleed up the cluch, if it gets easier when you pump the pedal theres most probably air in the hydraulics.
just like wooder94 said!
Posted 06 May 2012 - 07:54 AM
Id say clutch, does it go in reverse ok? If not then it is the clutch
