Anyone Else Haveing Problems With The Bt Infinty Home Hub?
11 replies to this topic
#1 Burnard
Burnard
  • 3,350 posts
Posted 04 May 2012 - 10:50 PM
Hi,
Ive got BT infinty, with the new home hub, had it for a while now, and NEVER been able to get my phone, tv, or blueray player to connect to it. they can all see it, and all try to connect, but it just doesnt happen.
Laptops work fine, so do wireless dongles in desktops, just not these devices...
Anyone got any idea's?
Chris
#2 mini77
mini77
  • 581 posts
Posted 04 May 2012 - 10:59 PM
yeh phone BT helpdesk :)
#3 1994alex
1994alex
  • 655 posts
  • Local Club: None yet :(
Posted 04 May 2012 - 11:01 PM
I have found that you are unable to watch tv or go onto the internet when someone rings the home phone -.-
#4 Mood 1990
Mood 1990
  • 59 posts
Posted 05 May 2012 - 12:08 AM
sounds like you might as well go back to dial up at that rate!
#5 Lily_Munster
Lily_Munster
  • 11 posts
Posted 05 May 2012 - 08:57 AM
Good luck with that! …it took a full week of hour long calls and one engineer visit to decide my home hub was broken! :-|
Mine had a red /purple/orange flashing light and could not connect to the internet.
Have you tried looking on any BT forums?
#6 2lrminivan
2lrminivan
  • 276 posts
Posted 05 May 2012 - 05:33 PM
search the net
bt are stupid bunch been waiting sine december for them to put a new line and a pole in to our camping field but they cannot seem to understand what i want even when bt open reach have told them what to do they still dont do it
#7 Msmith3327
Msmith3327
  • 220 posts
  • Local Club: Torbay Mini Club
Posted 05 May 2012 - 06:08 PM
Burnard, try the Home IT desk in BT rather than the Broadband Technical Team.
1994Alex, If your running normal Broadband Try a different Microfilter direct into the test socket behind the faceplate of the main socket then plug your Hub and phone direct into that, if it still happens ring the technical team, I your running infinity ring the infinity team direct for your issue.
2lrminivan, Is it a business line or a residential line they are trying to Fix? why are they replacing a pole and line?
#8 rosstolley
rosstolley
  • 111 posts
Posted 05 May 2012 - 09:34 PM
This is usually because you have another phone/device plugged into another socket without a micro filter.
#9 rosstolley
rosstolley
  • 111 posts
Posted 05 May 2012 - 09:43 PM
Depending on the age of your device's. You may need to change the wireless mode that your hub is operating. Try a different mode and see how that turns out.
Follow these steps to change your wireless mode:
  • Open your web browser and browse to http://bthomehub.home to open the Hub Manager.
  • If this is the first time you've accessed the Hub Manager you'll now be asked to change your password. Please follow instructions on the screen, then carry on with the steps below.
  • Click on the Settings tab.
  • Click on Advanced Settings on the righthand side of the top menu bar.
  • On the next screen, click on Continue to Advanced Settings.
  • Click on the Wireless menu option on the lefthand side of the top menu bar.
  • Change the wireless interface type to an alternative (if you've found that the b/g/n mixed mode does not work, we suggest you go down to b/g mode, rather than just b).
  • Click Apply.
  • You can now try to establish the wireless connection between the device and your BT Home Hub.
Try that and get back to me and i'll keep thinking! :proud:
#10 rosstolley
rosstolley
  • 111 posts
Posted 05 May 2012 - 09:55 PM
Infact... First try changing the network key from WAP/WPA2 which is the default, to WPA only. Do this via http://bthomehub.home
  • Select WPA only
  • Then click Apply
All done...
#11 Burnard
Burnard
  • 3,350 posts
Posted 06 May 2012 - 11:04 AM
I have tried all of that, and more, nothing works.
Im not phoneing the bt help desk because in the past they have done more harm than good.
I do have the number for the director of customer services uk, used that before and been sorted within the hour so might try that in the week.
#12 2lrminivan
2lrminivan
  • 276 posts
Posted 06 May 2012 - 04:52 PM
it a business line so we can have wifi aroung the camping field at www.hiddenvalleypark.com
