Rust And Mot!
Posted 04 May 2012 - 11:01 PM
Which exterior panels would rust prevent an MOT pass
Posted 04 May 2012 - 11:08 PM
Posted 05 May 2012 - 12:27 AM
all depends on the location of the rust on the particular panels
Yeah I know, that's what I'm asking lol...
Posted 05 May 2012 - 01:02 AM
To be frank, if you can cover it with paint and a screwdriver won't go through, then it'll be ok for the MOT. It'll only get worse though, and for the price of the paint, you could get a piece of fresh metal welded in.
Posted 05 May 2012 - 01:04 AM
Posted 05 May 2012 - 01:13 AM
Posted 05 May 2012 - 03:00 AM
However when you see some of the posts on here then there's all sorts of different areas that fail due to rust other than just these ones. I think a lot of it is down to the tester in question. If you are not sure with rust a quick test is to see whether you can push a screwdriver through it.
Other people may say differently but as a rough guide then most of the above is pertinent.
Posted 05 May 2012 - 01:29 PM
The MOT is not actually based on what is safe or unsafe, which is rather complex, and different for every type of car, but on what can be tested reasonably easily, while attempting to catch most dangerous problems. There are places where you could have a hole quite near to a suspension mounting without endangering the structure, but a definite MOT fail, and others more than the requisite distance from any suspension mounting, seatbelt, etc, which would make the car a deathtrap, but might pass the MOT.
A hole in the A panel is a MOT fail, on the grounds of jagged bodywork, and as it is quite close to the most highly stressed part of the Mini shell, a good tester would fail it for that too.
Hint: Find the thickest pieces of metal on the Mini. and you will be close to the most highly stressed areas.
Posted 05 May 2012 - 02:19 PM
In the boot of a Mini the floor must be sound within 30cm of the rear subframe mountings and also the rear lower seat belt mounts. Corrosion of the battery box bad enough to compromise the security of the battery will also fail.
As a matter of interest, shock absorber mountings are not counted as load bearing points unless the suspension spring is part of the shock absorber. The shocker mounting can be quite rotten, but providing the shocker still functions and the rot does not fall into the prescribed area (30cm) of ather component, then it is an advisory matter.
If you are still unsure, some photographs of the rust will help.
Posted 05 May 2012 - 04:47 PM
Posted 05 May 2012 - 10:23 PM
The more competent MOT testers will know that, and will fail it.
Posted 05 May 2012 - 10:36 PM
That would be the tin foil wrapped around my sandwiches in the boot! lol
You know what, for s**ts and giggles I think I'll put it back together when it arrives and cook it in for an MOT
Bing (1)
