Tie Rod Bushes
10 replies to this topic
#1 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 05 May 2012 - 11:00 AM
hard to change?
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 May 2012 - 11:03 AM
Not remotely.
#3 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 05 May 2012 - 11:47 AM
Not on the slightest. One of the easiest jobs you can do given their position.
#4 Wakey-Dan
Wakey-Dan
  • 256 posts
Posted 05 May 2012 - 05:27 PM
Just done this myself recently, actually a nice job to do, dead simple and well worth it.
#5 leroy26
leroy26
  • 2,239 posts
Posted 02 June 2012 - 07:06 PM
undo the bolt on the front valence, pop the old bush out smack the new one in?
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 June 2012 - 07:19 PM
Bolt ?? The bar will need to be removed from the lower suspension arm to get the inner bush out. This should be retained as a rubber bush - but the outer one should be replaced with a polyurethane bush , refit the fork end to the susp arm - and then tighten the front nut (not bolt!) as far up the thread as you can. You will then need to track the front wheels...
#7 leroy26
leroy26
  • 2,239 posts
Posted 02 June 2012 - 07:28 PM
haha meant nut! them ones by the front number plate
#8 Cooperman
  • 23,320 posts
Posted 02 June 2012 - 11:12 PM
They are 11/16" AF. I always use standard rubber bushes to reduce impact loads on the sub-frame 'ears'.
#9 tiger99
tiger99
  • 8,584 posts
Posted 03 June 2012 - 09:38 AM
I heard that when polyurethane bushes first appeared, there was an epidemic of fractured tie rods. They broke at the front end, which is unusual, as they normally go at the fork where they connect to the bottom arm. There seems to be good evidence that the combination of one rubber, one poly is safe (or 2 rubbers, obviously), but I still see people fitting all polys. Unfortunately these particular bushes, unlike almost all suspension bushes on all cars, do not operate in torsional shear but need to have the capability to compress too, which poly will not do.
#10 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 03 June 2012 - 09:44 AM
I discussed this with someone who grass track races their car yesterday and he is of the opinion that two standard bushes and regular replacement is the best option.
#11 tiger99
tiger99
  • 8,584 posts
Posted 03 June 2012 - 10:23 AM
Well, the standard bushes seem to be good for about 60,000 miles of moderately hard road use (ok in my case it was 50% motorway driving, which hardly stresses them, but 50% was on twisty roads and/or towns, with lots of braking and steering input, and far too many bumps), and don't take long to change, or cost very much, so that is a good way to go. I don't think that engine power affects them very much, the heaviest load by far is braking.
First rule of engineering: If it ain't broke, don't fix it. The standard bushes are not as broken as some people imagine, although I have said before that the design is rather poor. Will a poly bush in that position last 60,000 miles? I have my doubts.
