Purchased last year from Machine Mart, however due to a change in circumstances has never been used.
Complete in box and original packaging, with the user manual. This has only been out of the box for photo's..
I can take £165 for this, a great saving!
Any questions feel free to ask, postage will be around £12 or collection can be made from DE24 or DE56 area no problem.
- Power settings from 30 - 100amps. Welds mild steel up to 4mm thickness.
- Turbo fan cooling for improved duty cycle.
- Uses 0.6 / 0.9mm wire up to 5Kg spools.
- Fully variable electronic wire speed control.
- Thermal overload protection with auto reset. Unit operates from 230v, 13amp domestic power supply.
- Everything required to start `No Gas` welding is included, flux coated wire, professional style torch assembly, earth clamp & face shield.
- Converts easily to a conventional `Gas` MIG Welder with optional accessories. Full instructions supplied.
