Zcars Bosch Fuel Pump
Posted 07 May 2012 - 07:10 PM
tank outlet ------ pre filter------ bosch high pressure pump---- regulator----- fuel rail. is this how it goes?
the standard hayabusa fuel pump i bought from zcars is faulty by the looks of things, i should have put the £50 to the bosch set up instead of buying an old pump, hey ho that's the way it goes.
any help appreciated.
Ed
Posted 09 May 2012 - 11:41 AM
Posted 09 May 2012 - 12:55 PM
Great drawing, your a dab handy on the old autocad
Cheers,
Ed
Posted 10 May 2012 - 02:55 PM
The other way to do it without a tee is flow the fuel across the fuel rail -> from the pump n filters then in one side of the fuel rail out the other to the FPR......
Cheers on the cad thing, I sit using it every day for work and car stuff is way more interesting to me than the ships I have to draw.......
Edited by cptkirk, 10 May 2012 - 02:55 PM.
Posted 10 May 2012 - 03:11 PM
i have autocad in my laptop, but it takes me less time to draw it. i had done an introduction to autocad a few years back and enjoyed using it. i must keep using it
cheers for the help
Ed
Posted 10 May 2012 - 10:39 PM
Posted 11 May 2012 - 06:56 AM
Regards,
Ed
Posted 11 May 2012 - 12:49 PM
http://www.demon-twe...8&s=weber alpha
As cptkirk says really, if you follow the diagram the regulator fill sort out pressure balance. Autocad is ok for line drawings, but Really you should update to solidworks.
I use Inventor for my 3D work......same but different.....
Posted 11 May 2012 - 02:51 PM
Ed
Posted 11 May 2012 - 03:12 PM
Looks like a 3bar FPR will do you
Edited by cptkirk, 11 May 2012 - 03:14 PM.
Posted 11 May 2012 - 03:19 PM
http://www.ebay.co.u...#ht_1295wt_1037
what do you think?
Ed
Posted 07 June 2012 - 11:25 PM
Posted 08 June 2012 - 07:20 AM
Lee,Ed how you getting on with this now , do you need any pictures as I have a bosch pump on mine and a prv with the t piece in it. easyier to email it to you than convert the picture on here.
a photo would be great
Ed
