Drum brakes !
Steve Rowe
, Mar 03 2006 11:34 PM
23 replies to this topic
Posted 03 March 2006 - 11:34 PM
whats your thoughts on drum brakes all round (front and back) , on my new mini its got them its a 1340 which is abit worrying my mates dad say if there adjusted up right there good, should i keep them or swap the front for disks ? whats your views ?
thanks
thanks
Posted 03 March 2006 - 11:38 PM
I don't think i'd want drums all round with a 998 let alone a 1340!
But i'm sure you'll be ok if you maintain and service tehm well and drive carefully!
Posted 03 March 2006 - 11:42 PM
My advice would be definitely change to some discs and uprated ones and pads at that!!
Unfortuntely they will not be enough for that power !!! They need replacing with disks!!
Yes well maintained drums can have the same, and sometimes better initial stopping power than disks but if you brake from high speed then the drums will overheat and fade badly which is very dangerous !!!!!
Get them replaced ASAP !
Posted 03 March 2006 - 11:43 PM
Why would BL change them for discs when they upped the power if they were good enough? I say change them if possible. Especially now you have a 1340, the momentum in the car will be higher and you'll need more braking power to stop it.
Posted 04 March 2006 - 12:05 AM
I had drums all round on my '82' mayfair which was great because I was on 10" wheels but they were absolute C**p. I now have discs on 12" and they are so much better ( i did prefer 10" wheels but cooper discs were out of my price range), so my opinion.........................get discs
Posted 04 March 2006 - 08:16 AM
yes your going to need some disks up front
we even have some disks for mrs bungles moded 998
Posted 04 March 2006 - 08:23 AM
get discs steve.
Posted 04 March 2006 - 09:17 AM
Yep, I'd have to go with this lot-upgrade to disks. I'm even saving up for some disks for my pickup and that's only got a 998 in it
Posted 04 March 2006 - 11:13 AM
some of the replys are funny thanks everyone its what i wanted to hear to make my mind up , ive got another mini with the disks setup on the front is it just a swap over or more harder than that ?
Posted 04 March 2006 - 11:19 AM
depends on the wheels. if you have 10s on the drummed mini, and 12s on the disked, then you'll need 12s on the swap. It may also mean you need to swap the rear drums if the rears on the drummed one don't have the inbuilt spacers.
If you have both on 10s, or both on 12s/13s, then swap away!
Posted 04 March 2006 - 11:21 AM
To have disks on tens you need 7.9" cooper s disks (£500)
Unfortunately the standard mini disks will not fit with 10" wheels as they are 8.4"
Posted 04 March 2006 - 11:30 AM
yeah runs on 10inch mambas and the disks are for 12's , the idea the now is to get it mot and have a few track days while im saving for the cooper s brake set up , its it a bad idea to run 10s on the rear and 12s on the front ?
Posted 04 March 2006 - 01:08 PM
do mambas fit under cooper s disks or is it just the 7.9 disks they wont fit under ?
Posted 04 March 2006 - 02:11 PM
mambas will fit on cooper s discs but not the 67.9" discs and not with 4pots!
