998 Or 1098?
30 replies to this topic
#1 chipmongrel360
chipmongrel360
  • 103 posts
Posted 09 May 2012 - 04:18 PM
reposting this as i lost the original thread when the site was last hacked.
basically i'm planning an engine build over summer, and I've currently got a complete high-mileage 998 engine as my starting point.
i'm led to understand that a 998 can rev higher than a 1098 but the 1098 has more torque.
i plan to drop the finished engine into my mini which is a daily driver, and overall my aim for the engine is for it to be fun and responsive, as well as having enough power to embarrass the local saxo and 206 owners...
i'm wondering what peoples opinions are as to which direction to go, should i keep it 998 or up it to 1098? bearing in mind that this will be my first ever engine build, should i perhaps keep it 998, and then make a 1098 out of the engine that it will replace i.e. the one that's currently in the mini?
cheers,chris
#2 minimarco
minimarco
  • 1,950 posts
Posted 09 May 2012 - 04:38 PM
You should ask around and try someone's 1098.
It's hard to describe exactly what it feels like, but it just seems to require less work to go up hill or cruise at speed. I don't know if I would call that fun compared to flooring the 998 everywhere but everything is just easier in a 1098.
I personally would suggest keeping the 998. Just to experience it before moving bigger because it's fun in its own way. It's always hard to downsize.
#3 Guest_jack mac_*
Guest_jack mac_*
  • Guests
Posted 09 May 2012 - 04:41 PM
Really interested in this , I've been thinking about the similar sort of spec (saxo killer) in a few years , gonna stick with a 998 for insurance at the min though
#4 Tupers
Tupers
  • 4,156 posts
Posted 09 May 2012 - 05:40 PM
If it's for a daily driver I'd go for a 1098. Maybe stick a 1275 head on it and a Kent 266 or SW5 cam and you'll have a lovely smooth engine for cruising about with.
#5 chipmongrel360
chipmongrel360
  • 103 posts
Posted 09 May 2012 - 10:45 PM
ah if only it were that simple, i rarely see other minis around here, i reckon I've seen two or three within the last year, always manage to see them when i'm not in my mini :/
anyway, you say it takes less effort to get up to hills or get up to speed. this would be my major concern, i love the 998 cause it's always very dramatic when accelerating i.e. lots of noise and revs, would the 1098 sound more civilised compared to that? i know the 1098 will not be a quiet engine, but does it have the same theatrics that the 998 has.
#6 minimarco
minimarco
  • 1,950 posts
Posted 10 May 2012 - 12:01 AM
I can't be certain to decibel points, but when I switched my 998 for a 1098, they sounded about the same noise level wise. The 1098 does have a lower tone though, it's throatier.
If you want theatrics, put in a set of straight cut drop gears. They sound like a tank driving down the street.
How long have you been driving your 998?
#7 thebullet
thebullet
  • 1,337 posts
Posted 10 May 2012 - 10:22 AM
998, you can't beat how it revs!
#8 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 10 May 2012 - 12:49 PM
Yer I say 998, the 1098's have a tendency to burn oil, with a 1098 you can run a different final drive, which would make it good for cruising something like a 3.1 or even 2.9 would be happy on a 1098. I've got a 3.44 on my 1098 and if I'm honest its pants, and I wish it was a 3.1
Edited by liirge, 10 May 2012 - 12:50 PM.
#9 chipmongrel360
chipmongrel360
  • 103 posts
Posted 10 May 2012 - 06:24 PM
i've been driving it just over a year, though its only been my daily driver since march.
i've decided to stay with the 998, purely on the basis that it will be an easier build. i reckon i'll have enough to learn about without having to worry about rebores and the like. now i've just got to make a spec list for the build and figure out a way to finance it lol.
if all goes well, i'll do another rebuild of the current engine in the mini, i.e. the one that'll be replaced, and make it a 1098.
#10 oltonlad
oltonlad
  • 2,401 posts
Posted 10 May 2012 - 06:34 PM
a 1098 quiet.....haha......have a listen to this and tell me if you think that its quiet!!...............;-)
the 1098 is a great engine to drive
or this.....its the same car........
#11 minimarco
minimarco
  • 1,950 posts
Posted 10 May 2012 - 06:54 PM
lol
Is that what my car sounds like from the outside? I've only been inside it driving.
I'd hate me if I was my neighbor.
I think that's a good idea.
Edited by minimarco, 10 May 2012 - 06:57 PM.
#12 thebullet
thebullet
  • 1,337 posts
Posted 10 May 2012 - 07:20 PM
a 1098 quiet.....haha......have a listen to this and tell me if you think that its quiet!!............... ;-)
:wub:
#13 josrey
josrey
  • 92 posts
Posted 23 September 2014 - 11:16 AM
You've probably already done and finished this but you would not have had to rebore that engine to make it a 1098 as the 998 and the 1098 engine are the same apart from the 1098 has a longer stroke basically its a 998 with shorter con rods.
Edited by josrey, 23 September 2014 - 11:17 AM.
#14 Cooperman
  • 23,329 posts
Posted 23 September 2014 - 11:54 AM
One really good option is to bore the 998 to +0.080" thus achieving 1060 cc. It will still be able to rev to around 7000 rpm (if balanced and with top quality pistons), but with, say, a 266 cam it will have improved low-end torque. Thus it's a 'win, win' situation in terms of driveability.
Never rev a 1098 past about 6000 rpm unless you want to risk a crank failure with the consequent gearbox damage.
#15 Fozz
Fozz
  • 145 posts
  • Location: Roeselare, near to Ypres (Westflanders, Belgium).
Posted 30 October 2014 - 06:47 PM
Could somebody explain me the exact difference between a 998 and 1098cc plz? Are the cranckshafts different? Pistons? I know the 1098 is a long stroke engine, but what is different in both engines??? Regards.
