Oil Leak!
7 replies to this topic
#1 mini77
mini77
  • 581 posts
Posted 12 May 2012 - 08:36 PM
Its not the gearbox or engine gaskets what else could it be please? Also I've heard minis are prone to to oil leaks...is this correct?
#2 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 12 May 2012 - 08:44 PM
Oh yes, Mini's are very good at leaking oil. What I do is park it on a sheet of light coloured paper and come back in the morning, the leak will be directly above where the oil is (except whern it's running down something else). Most common place for it to leak from is probably the selector rod seal.
#3 abe46
abe46
  • 431 posts
  • Local Club: South Devon Mini Club
Posted 12 May 2012 - 11:53 PM
I would be worried if it didn't have a leak! In which case someone might have put a VTEC or Vauxhall lump under the bonnet ;)
But as mini luke mentioned, the selected rod seal is a very common one. The leak seal kit is not very expensive on minispares if you do find that it is leaking from there!
Another place could be through the inner pot joints. Sheet of coloured paper is a great idea mentioned above, give that a go and present your findings!
Oh and it's not an oil leak... It's character :shades:
#4 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 13 May 2012 - 07:26 AM
It's marking it's territory on the garage floor :lol:
#5 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 13 May 2012 - 08:38 AM
i read a properly produced book on minis.
and it states that minis were designed to leak oil to help protect the subframe from rusting.
its actually printed as though its fact.
#6 oltonlad
oltonlad
  • 2,401 posts
Posted 13 May 2012 - 08:46 AM
mine doesent leak oil (yet) but give it a chance, the engine's only been in the car for 2 weeks!..................... :D
#7 oltonlad
oltonlad
  • 2,401 posts
Posted 13 May 2012 - 08:50 AM
the main areas of oil leaks on a mini are :- everywhere!
as said above, the most common culprits are gear selector seal, pot joint seals, crankshaft oil seal, rocker cover gasket, head gasket.
#8 valve bounce
valve bounce
  • 694 posts
Posted 13 May 2012 - 11:03 AM
they dont leak oil they have an automatic front subframe rust proofing system :proud:
Edited by valve bounce, 13 May 2012 - 11:04 AM.
