Engine judder
9 replies to this topic
#1 c18rch
c18rch
    Starting My Mini Up
  • 2 posts
Posted 04 March 2006 - 06:31 PM
Hi
Ive got a 96 john cooper. When i am not accelerating or when im backing off the accelerator slightly the engine will judder quite badly. It makes the whole car judder. It feels like someone jabbing the accelator repeatedly. The problem is worse in 2nd and 3rd.
Has anyone got any ideas because ive run out.
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 04 March 2006 - 06:44 PM
If you try grabbing the rocker cover does the engine rock backwards and forwards??? If so, you need new steady bushes and possibly new bottom engine mounts...
#3 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 04 March 2006 - 08:25 PM
Yip, sounds like engine mounts..
Not to hard to replace... and not too expensive either
#4 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 04 March 2006 - 08:51 PM
something else to check out for if it is the engine steady bushes, is has the jet been hitting the bukhead, this happened to me and i had to get a new jet and needle..
keep this in mind
#5 THedooBZ
THedooBZ
  • 887 posts
Posted 05 March 2006 - 09:17 AM
cowboy if its a 96' itll probably be spi, so it wont be a problem due to it being injection
#6 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 05 March 2006 - 09:23 AM
good point, that will remind me to to think about the post, but he also didnt mention that fact
lol
#7 c18rch
c18rch
    Starting My Mini Up
  • 2 posts
Posted 06 March 2006 - 10:50 AM
Its not the engine mounts or bushes. I had these replaced when i bought it.
I think I may have solved it though. I was driving it yesterday and there was a loud bang and a puff of smoke from under the engine. When I looked to see what it was the HT lead offf the first cylinder had blown off the distributor (for lackk of a better word its one of those bloody no mechanical things) and the connections were covered in water or somthing so ill replace that and see how in goes.
#8 topcat
topcat
  • 276 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 06 March 2006 - 01:27 PM
Check the front subframe teardrop bushes! At the front of the front subframe - between the bodywork and subframe there are two teardrop shaped bushes. They may look OK but try pulling the bodywork away from the subframe to see if there is any movement.
Also you can check by turning the steering wheel from side to side when stationary and look to see if the engine is moving from side to side.
#9 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 06 March 2006 - 01:39 PM
Hi
It seems to me that p'raps we've misread the problem maybe?
I would the juddering was a misfire? Unless I am misreading the problem?
#10 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 06 March 2006 - 03:34 PM
Hi
Sounds more like a fuel injection problem to me..... :D
