Basically the engine is out, front wheel hubs stripped, subframe removed.
The idea was for the engine to go back in after a rebuild thought i would take care of the engine bay clean it up and new lick of paint, then decided to change to solid mounts now im cleaning up the wheel hubs, brakes and suspension related parts as well as new shocks.
Now i've bitten the bullet big style and i am going to replace the front end as its a mess especially around the lights, grill and subframe mounts! It has had two new wings at some point probably at different time points so will see what i can salvage the older one probably getting replaced as the underside had no protection and is rusting through.
Windscreen panel is shot at the bottom corner usual place getting a repair patch for that.
