Keys, Locks And Ignition Barrel
Posted 15 May 2012 - 11:08 PM
Previous owner lost the keys, so although everything matches as they haven't been changed, I have no keys. Obviously getting some new ones is better than replacing all the locks and ignition barrel.
Suggestions as to where I can get some, and how to find whatever identifying marks it is I need to get them cut to the required pattern, would be very much appreciated.
Posted 16 May 2012 - 07:42 AM
if you take the door handle off ( which is only 2 screws) if you look at the end of the lock barrel there is a code stamped into the end of it that will be the key code.if you know a mobile car locksmith they can usually cut one there and then.alternatively i have seen the boot and two door lock set on ebay brand new for about 26 quid delivered!
Posted 16 May 2012 - 09:01 AM
Posted 16 May 2012 - 09:08 AM
Posted 16 May 2012 - 09:12 AM
I guess it's 'easier' to just get a lock set and a new barrel. Like bulldogthirty4 said, they're quite cheap on eBay.
Posted 16 May 2012 - 09:36 AM
Although I've just realised I'm making assumptions about the age of this car, what Mini is it?
Edited by Dan, 16 May 2012 - 09:36 AM.
Posted 16 May 2012 - 10:13 AM
Already undone the shear bolts, had to because the steering lock was on!
Not the first time I've had the 'pleasure' of doing that either.
Ignition connector is a multiplug with male spade terminals, 4 wires.
Found a couple on eBay, so I guess I'll just have to bite the bullet eventually and get the damned thing.
The door locks and catches seem nice and tight, so I'll chase around for a local key-cutter who can cut for the lockset.
Posted 31 March 2016 - 09:31 AM
For any type of locked door problem,ignition problem,contact Hollywood locksmith.I have a car problem for any mechanically inclined folks out there. The ignition on my girlfriend's car locked up tonight while she stopped at a gas station on the way home. She had to have it towed back here. The key would not turn at all, not even to the on position. The car (an automatic) was in park with wheels pointed straight ahead. No problems removing or inserting the key, and the key does not appear to be damaged in any way. This was not the normal anti-theft wheel/ignition lock.This happened once before (about two years ago).I contact kollywood locksmith in future also because only they can only resolve my problem.
