My Standard Round Nose Sportspack Vtec Mini Build
14 replies to this topic
#1 79 clubby
79 clubby
  • 165 posts
  • Local Club: .
Posted 18 May 2012 - 07:38 PM
Hi All,
this is the start of my vtec mini build so i am sure there will be lots of questions that you guys can help me with. heres a couple of pics of the honda that i started to strip
#2 79 clubby
79 clubby
  • 165 posts
  • Local Club: .
Posted 18 May 2012 - 07:42 PM
Hi all
i keep for getting to update my vtec build i now have the minitec mtb2 subframe kit, set of coilovers and the steering kit coming from minitec i have fitted the subframe and engine to my mini with no problems but i am now looking at the brake master cylinder which one do you guys fit? as the standard servo hits the dizzy on my b18c4 anyway heres a pic of my mini so far...........
  • Attached File  096.JPG   72.07K   45 downloads
#3 johny:)
johny:)
  • 311 posts
Posted 19 May 2012 - 09:43 AM
that looks good mate you got the subframe ok then? have you tried fitting the steering collom yet? mini looks good what are you going to do about the manifold i found it easy to just move the bulck head back i made mine abit big but got plenty of room to get my hands in there and mess about try and get a few more picks up intrested to see how it comes allong
#4 79 clubby
79 clubby
  • 165 posts
  • Local Club: .
Posted 19 May 2012 - 09:55 PM
i got the subframe in the end after paying the customs fees but as you said it's well worth the money. do you mean have i tryed to fit the steering rack? if so then yes i have and it does'nt fit as the rear engine mount hits the steering rack so i have the rhd steering kit from mini tec now to make it easy for me. i have the standard exhaust manifold and am looking at getting a skunk 2 inlet manifold and cutting it and rewelding it so hopfulley i don't have to cut the bulkhead . i will get some more pics up as soon as i do some more work on it.
#5 Ro3ert
Ro3ert
  • 110 posts
  • Local Club: Geeks and freaks (York)
Posted 20 May 2012 - 12:57 PM
What engine is going in? also what frame are you using?
#6 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 20 May 2012 - 06:51 PM
#7 Ro3ert
Ro3ert
  • 110 posts
Posted 20 May 2012 - 07:28 PM
My bad, i need to read things properly. :ohno:
#8 joel93
joel93
  • 148 posts
  • Local Club: h.p.m club
Posted 25 May 2012 - 10:17 AM
is 79 clubby fitting the vtec with the front end attached ? I thought you needed a flip front ? also is there any companies who can fit the the lot for me if i provide the mini and vtec downer car ?
thanks.
#9 Kam
Kam
  • 4,140 posts
Posted 25 May 2012 - 08:12 PM
You can keep the front end as it is, but good luck on working on it after - or even during the build, you would need to keep lifting the car over the engine or raise the car on a 4 poster and drop the engine/subframe which is hardly for everyone...
Make no mistake, even a solid clubman front with its extra 10cm (or so) extension seems like you got loads of room but its still a world for people with small hands, or women :whistling:
Theres a few companies that can do you a drive in drive out but the cost side is the thing
#10 79 clubby
79 clubby
  • 165 posts
  • Local Club: .
Posted 25 May 2012 - 08:26 PM
i will be keeping the standard steel front on as i want the mini to look as standard as possable. it was not that hard to lift the shell over the engine but Kam is right about working on the engine but i think it will be worth all the hassle.
#11 Kam
Kam
  • 4,140 posts
Posted 25 May 2012 - 08:40 PM
I'm trying to have a removable front end with no visible fixings but I can't with my ability so it is what it is, people at mini shows are eagle eye and will know it don't look right but more importantly the everyday minions out on the roads won't have a clue so thats good enough for me!
Fair play to you though, you don't get more hidden fixings then a welded up front - kudos there pal! :thumbsup:
#12 79 clubby
79 clubby
  • 165 posts
  • Local Club: .
Posted 25 May 2012 - 10:31 PM
thanks Kam i will try and get some more pics up of it
#13 Spoonz
Spoonz
  • 331 posts
Posted 31 May 2012 - 04:53 PM
How much import tax did u have to pay. That is the kit I'm looking at getting. And how long did it take for it to arrive ?? The import tax is what I'm worried about the most :( do they phone u and say "pay up!?" before releasing it etc ?
Thanks.
Great project
#14 paul190181
paul190181
  • 193 posts
Posted 14 June 2012 - 04:01 PM
Looking good . It's not to bad at all to work on the car with the front end on worst thing would be ud probably need the engine out to change the cambelt apart from that you can get to all u need .
#15 johny:)
johny:)
  • 311 posts
Posted 17 June 2012 - 04:11 PM
My subframe only took a few days to reach the the uk mini tec will give you a tracking number it was then held up in customs for a few days as they didnt have a contact number for me the customs is 20 percent of what you pay for the kit
Thanks.
Great project
