Rust Holes Driver Footwell
7 replies to this topic
#1 stormintrooper
stormintrooper
  • 2,072 posts
Posted 21 May 2012 - 12:52 AM
found sum holes in the footwell today :(
right at the edge where the panel (from the underside of car) angles upwards by the subframe mounts
not exactly got the pare time to have the car off the road for major repairs...but i need some advice on how to proceed with this, i know i could just have it plated over...which im not too keen on the idea as it doesnt solve the issues of the rust already there
#2 HafMan
HafMan
  • 383 posts
Posted 21 May 2012 - 05:40 AM
Cut it out and weld in a patch if its not too bad
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 May 2012 - 05:57 AM
a wire cup brush on a angle grinder will remove all the rust
once this is done tidy up the hole with a cutting disk to a shape you can make a patch for
then weld a new bit of metal in
repaint and your back on the road
just remember to remove carpets and trim and protect the interior from sparks etc
#4 stormintrooper
stormintrooper
  • 2,072 posts
Posted 21 May 2012 - 10:50 PM
don't have an angle grinder, can't you get the same sorta thing that goes onto the end of a drill?
will they work just as good?
Edited by stormintrooper, 21 May 2012 - 11:17 PM.
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 May 2012 - 06:37 AM
just buy a angle grinder, they are cheap in the DIY sheds and will clean the rust + cut the square hole
#6 stormintrooper
stormintrooper
  • 2,072 posts
Posted 22 May 2012 - 11:26 AM
id just be making a bigger hole with no equipment to weld it back up :)
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,096 posts
  • Name: Neil
Posted 22 May 2012 - 11:30 AM
If you do all of the prep work then it won't cost you as much to get a plate welded in place. Do you not know anybody with a welder who could do it for you. Even a local mini club could help out.
#8 stormintrooper
stormintrooper
  • 2,072 posts
Posted 22 May 2012 - 05:43 PM
unfortunately no, but yh good idea didnt think about the less working time for them :)
Edited by stormintrooper, 22 May 2012 - 06:05 PM.
