Over-Riders And Corner Bar - Fitting.
17 replies to this topic
#1 feeenix14
feeenix14
  • 130 posts
Posted 21 May 2012 - 03:33 PM
Hello all,
I know its second nature to most people on here to fit these but i did it at the weekend and took pictures as i went so thought it might help others if i did a bit of a how-to. This is only a guide and it might not be 100% correct but it seemed to work for me so:
You will need -
Your over-rider and corner bar kit with all fittings.
Masking tape
Pen or pencil
Drill with various drill-bits 3mm upwards
Sockets and spanners
Patience
Step 1.
Take your over-rider and your corner bar and assemble the 2 using the correct bolt and washer. Then trial fit onto your bumper and when you are happy with where the corner bar and over-rider are sitting attach the over-rider to the bumper (just finger tight at this point) as in picture below.
Attached File  4.JPG   32.44K   163 downloads
Step 2.
Take some masking tape and stick it on your bumper underneath where your corner bar is going to be fitted. It should be easy enough because the corner bar will sit off the bumper a few mm so you can slide it underneath as in picture below. Once you have the masking tape on there take a pen or pencil and draw around the corner bar. As in picture below.
Attached File  1.JPG   39.29K   97 downloads
Step 3.
Take your over-rider and corner bar assembly off and place safely to one side, take your pen again and mark off the centre of the oval you have just made when you drew around your corner bar. Then get your drill and put a small drill-bit in there to drill a pilot hole. I started with a 3mm bit. Take your time and dont be too heavy handed. Once through step up to a bigger drill bit, i think i used an 8.5mm but this was a bit tight but you can keep checking with your parts as you go. Its better to not take enough and re-do it than to take too much off. As below.
Attached File  2.JPG   30.61K   61 downloads
Then once have opened out the hole take the masking tape off. Dont do what i did and just pull it off and screw it up in your hand because it will have super sharp bits of metal shavings stuck to it that will cut your hands when you screw it up. See pic.
Attached File  3.JPG   38.82K   67 downloads
Step 4.
Re-attach your over-rider and corner bar, finger tight again, and put your bolt throught the spring washer and then through angled lump of metal thing. then slot that through your hole and into the corner bar. This took quite a few attempts to get it lined up and get it to thread in but be patient and it will go in eventually. As you can see for some reason my holes were in line with the bumper supports but these are pretty soft so i just bent a bit out of the way so i could get my socket on there. See pic.
Attached File  5.JPG   27.16K   105 downloads
Once done tighten that up and then tighten up the bolt on your over-rider and you've done your first one. Repeat steps for the other 3 corners
Attached File  6.JPG   218.94K   90 downloads
Voila.
hope it helps somebody
Sam
#2 minimaxie
minimaxie
  • 1,687 posts
Posted 21 May 2012 - 03:44 PM
brilliant guide! thanks shall be using this when i get my overriders :D
#3 TfcIan
TfcIan
  • 537 posts
Posted 21 May 2012 - 04:21 PM
Where was this a week ago when I asked the question. Good guide, I was surprised when I couldn't find one but I'm sure this will help a lot of people.
#4 Joseph-C
Joseph-C
  • 383 posts
Posted 22 May 2012 - 08:29 AM
Great guide this needs to be moved to the FAQ section so it doesn't get lost :D
#5 joeyfinneran
joeyfinneran
  • 511 posts
  • Local Club: imoc
Posted 22 May 2012 - 07:52 PM
great guide and would look to be using it but the price of the kits are stupid :ohno:
#6 minimarco
minimarco
  • 1,950 posts
Posted 27 May 2012 - 11:51 PM
Have a set coming, I'll be referring to this guide. Thanks!
Put this in the FAQ, someone.
#7 james962
james962
  • 2,677 posts
Posted 28 May 2012 - 07:04 AM
Well done. We need more of these fitting guides really. It's just remembering at the time to take pictures :lol:
#8 jamiegjib
jamiegjib
  • 29 posts
Posted 28 May 2012 - 11:54 PM
brill thanks!
#9 ToM 2012
ToM 2012
  • 4,066 posts
Posted 21 October 2012 - 05:03 PM
great sam just what i needed will be fitting them tomorrow cheers tom
#10 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 19 January 2013 - 11:19 AM
just about to use this guide
#11 ChubytheMINI
ChubytheMINI
    Just On Tickover
  • 8 posts
Posted 02 April 2017 - 11:36 PM
Thank you matey!
#12 noeman
noeman
  • 125 posts
Posted 29 May 2019 - 07:02 AM
Excellent, I had no idea what way round the bracket under the bumper went as my over riders came with no instructions. Your photos are a big help.
#13 Tornado99
Tornado99
  • 750 posts
Posted 30 July 2020 - 06:12 PM
Good guide indeed. Question: Is drilling through a chromed bumper a problem? Can't tell from the pictures if this was on a chrome or stainless bumper.
#14 I hate Brian
I hate Brian
  • 782 posts
Posted 30 July 2020 - 07:16 PM
Excellent guide
#15 geachy87
geachy87
  • Just Joined
  • 48 posts
Posted 04 August 2020 - 01:10 PM
Going by the rust on the underside, I’d say it’s a chrome bumper in the pics
