Welding Clamps At Lidl.
13 replies to this topic
#1 HARRYSPADGE
HARRYSPADGE
  • 19 posts
Posted 21 May 2012 - 08:08 PM
Hi,
I don't know if anyone would be interested in this but Lidl are doing some clamps at the moment that are ideal for welding.
They come as a set of three mole grip type clamps for £4.99 and at that price I don't think you can go wrong.
Got myself a few sets ready for when I tackle the welding on my two projects. :-)
May just be worth a little look if your in need of some.
#2 Spiffingly Good
Spiffingly Good
  • 441 posts
Posted 21 May 2012 - 08:42 PM
Edited as I'm fool :shifty:
Edited by Spiffingly Good, 21 May 2012 - 08:58 PM.
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 May 2012 - 08:46 PM
thanks
#4 HARRYSPADGE
HARRYSPADGE
  • 19 posts
Posted 21 May 2012 - 08:53 PM
Thought i'd stick up the link so people can see them, I'm sure there enough for welding and you can never have too many clamps!
http://www.lidl.co.u...index_31271.htm
That link doesn't take you straight to them, which is why I didn't bother posting it.
You can see them though, if you select today's special buys at the top of the page and then enter your postcode.
Edited by HARRYSPADGE, 21 May 2012 - 08:55 PM.
#5 MR J
MR J
  • 416 posts
  • Local Club: Doncaster Mini Owners
Posted 21 May 2012 - 08:57 PM
The generator looks like a good deal also, 4 stroke, 2800W for £179, bit noisey for camping though I think.
#6 HARRYSPADGE
HARRYSPADGE
  • 19 posts
Posted 21 May 2012 - 09:10 PM
The generator is a great bit of kit.
I bought one last year for my work, to run my power tools when I'm doing fencing and such like.
And it's actually not too noisy, well I don't think so anyway.
Edited by HARRYSPADGE, 21 May 2012 - 09:11 PM.
#7 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 21 May 2012 - 09:35 PM
or click continue without postcode below ;)
Wounder if those arc welders are any good, cant go wrong for £35
#8 ibrooks
ibrooks
  • 1,017 posts
Posted 23 May 2012 - 11:42 AM
But what on earth would you use an arc welder for nowadays? OK they are cheap but £35 sat under the bench in the workshop for ever more is a bit pointless.
I'll be checking on the local store for the clamps - I have a set and they are useful but I often find myself wishing I had two of whichever type I'm using so a second set is a definite purchase.
Iain
#9 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 24 May 2012 - 07:59 AM
that arc welder is 40-80 amps... bascially pointless as an arc welder, when i learnt arc welding i was welding 10mm plate up and the test pieces where 5mm... that welder woudnt even touch anything like that so fully a waste on £35.
arc welding is still used though,,,
as for the clamps dont see why they would be that bad.. altough i use irwin visegrip ones.. which are the blllks to be fair!
#10 markosparko1994
markosparko1994
  • 235 posts
Posted 24 May 2012 - 08:43 AM
there is often lots of good stuff at lidl , they just buy in whatever is cheap at the time
#11 ibrooks
ibrooks
  • 1,017 posts
Posted 24 May 2012 - 02:27 PM
Yeah - I suppose I should have said "what the hell would you use an arc welder at home for".
I learnt on big oil-filled things welding lumps of quarter plate together. I've got an arc welder and my TIG set can be converted to arc as well but the one time I can remember that I've used arc since college was to weld a steel shaft onto a sledge-hammer and that was only because someone had borrowed my MIG (and I didn't have the TIG set at the time).
Iain
#12 Brams96
Brams96
  • 2,308 posts
Posted 25 May 2012 - 12:59 PM
Does anyone know if the compressor is any good. It's quite cheap ;-)
#13 HARRYSPADGE
HARRYSPADGE
  • 19 posts
Posted 25 May 2012 - 06:25 PM
The quality of Lidl stuff I find is always pretty good for the money.
The real question is what will you be trying to run off this compressor ?
I have a very similar unit which I can run air nailers with quite sufficiently, the only problem with these small compressors is the tank size.
They don't hold enough air pressure to run very hungry tools with, so tools such as air sanders, spray guns, impact guns will drain the tank very quickly. The compressor itself is not man enough to refill the tank quickly enough, so you will find that the more powerful air tools will very quickly lag in power.
If your only going to use it for light duties then I would definitely recommend getting one.
I've also noticed they are now doing 6" air sanders so I'm definitely going to be getting one of those at that price.
And yes, I have a very large compressor that I will be running this on - has a 250ltr tank. :-)
Edited by HARRYSPADGE, 25 May 2012 - 06:26 PM.
#14 Chance
Chance
  • 1,457 posts
Posted 25 May 2012 - 06:30 PM
Aldi have a compressor for 100quid...havent looked at lidl just thought id let you know. Theres a thread about it on here somewhere..2.5hp is all i can remeber maybe 25litre capacity
Just let you know so you can compare both stores offerings :)
