Swap Auto To Manuel?
30 replies to this topic
#16 iDemonix
iDemonix
  • 963 posts
Posted 20 June 2012 - 09:28 PM
Keep this thread updated as I'm in the same position!
Got a 998 auto in the car and a 1275 manual in the garage, but not much mechanical knowledge! Would like to do the swap myself but still think I'd be in over my head.
Are you using the current subframe or swapping for a new one? You can buy spacer plates for auto subframes but seems a bodge to me so I'm getting a manual subby.
#17 colinjames11
colinjames11
  • 34 posts
Posted 21 June 2012 - 07:04 AM
I was going to opp for the space plates since minispares is a 5minute drive from me that and one day i might swsp it back to its original auto engine. Did the pedal box this morning :) took like 5mins haha pics coming soonAttached File  20120531_160511.jpg   53.42K   5 downloads
#18 colinjames11
colinjames11
  • 34 posts
Posted 21 June 2012 - 08:31 PM
Im keeping the sub and getting spacer plates. Think im going to get thr engine refurbed having a friend look at it soon. Any idea of the internal bore of a 1275? Im in the same situation my mechanial knowledge is nexr to nothing haha
#19 colinjames11
colinjames11
  • 34 posts
Posted 30 June 2012 - 03:27 PM
Looking into speeding the engine up. Im going to put a stage one on it but not sure what else to do im going to get a new single hif44 carb and the stage one possibly larger valves since one is bent. New uprated alternator and radiator. Not sure if a gt one or one of those 2 core aluminium ones. Im not looking to build a race car just want it to be nippy. Any ideas of what might be a good idea? :)
#20 Spitz
Spitz
  • 1,716 posts
Posted 30 June 2012 - 03:53 PM
Standard bore for the 1275 is 2.78" ( 70.61mm )
Demonix.....the 3/8" spacer each side isn't a bodge....It's a lot less work than replacing the subframe that's for sure. Plus, it'll give you that little bit more room on either side....like getting at the clutch cover bolts etc.
One hole does need to be drilled on the left side of subframe ....rear engine mount hole ( edit...might be the front hole, can't remember )
Edited by Spitz, 30 June 2012 - 03:54 PM.
#21 colinjames11
colinjames11
  • 34 posts
Posted 30 June 2012 - 04:06 PM
Haha i'll let you know once im closer to the day of installing it. Atm im cleaning up the engine needs some work including new clutch plate and all that funstuff so atm not 100% sure on set up but definetely going for the spacer plates. Any recomendations on a good carb set up mechanically minded im an absolute noob but practically i can do most things haha. Wanted twin set up but cant afford anything :/
#22 Jimmy Hat
Jimmy Hat
  • 960 posts
Posted 30 June 2012 - 04:20 PM
Old one, I know...
Edited by Jimmy Hat, 30 June 2012 - 04:21 PM.
#23 iDemonix
iDemonix
  • 963 posts
Posted 30 June 2012 - 06:20 PM
I know it's not a 'bodge' but whilst the engine is out it'd be a good idea to fit new subframe poly or solid mounts, hammerite the subby, check it all over etc. It has some corrosion too, so since I'd probably take it out to work on it, might as well fit the proper one!
#24 colinjames11
colinjames11
  • 34 posts
Posted 01 July 2012 - 08:43 PM
Bored so thought id just show how much work done on my mini so far.
Attached File  9624_131343435665_4979247_n.jpeg   64.62K   2 downloadsAttached File  9624_131343415665_2793008_n.jpeg   64.87K   2 downloads
So thats what it looked like when i first got it.
Attached File  171736_495822600665_16771_o.jpeg   33.98K   1 downloadsAttached File  171781_495820825665_1506027_o.jpeg   46.42K   2 downloadsAttached File  251535_10150249976095666_572415_n.jpeg   82.99K   3 downloadsAttached File  324623_10150547146405666_380153327_o.jpeg   61.51K   3 downloads
Thats what it looks like now/while had work done. New bumpers and sportspack fibre glass arches to beef it out 7x13 super light rims. Cherry red leather seats inside. New carpet, also dash rrcently put in. hope everyone like :)
#25 Spitz
Spitz
  • 1,716 posts
Posted 01 July 2012 - 09:49 PM
Looking good.
I just noticed your screen name.
http://www.colinjames.com/
excellent guitarist
#26 colinjames11
colinjames11
  • 34 posts
Posted 03 July 2012 - 08:32 PM
Valve wasnt bent just siezed tap with hammer after applying wd40 got it free :). Will paint it up tomorrow. Get some pics. I like some of this guys songs obviously he has an awesome name to :)
#27 colinjames11
colinjames11
  • 34 posts
Posted 03 July 2012 - 08:33 PM
#28 colinjames11
colinjames11
  • 34 posts
Posted 05 July 2012 - 07:47 AM
Head painted this morning :). Thinking of getting the valves all swapped over i know it'll be a bit of money and not something i can do but i dont want the valve to sieze again :/ anyone got a clue what valves i should be putting in? And possible cost?Attached File  20120705_083239.jpg   89.18K   3 downloads
#29 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
Posted 05 July 2012 - 10:02 AM
im soon changing my auto 998 to a manual in my 74 clubman as its siezed
#30 colinjames11
colinjames11
  • 34 posts
Posted 05 July 2012 - 01:21 PM
Planning anything fancy or just a 998 manual going in?
