Running Without A Fan
Posted 22 May 2012 - 08:38 PM
As I need the car tomorrow I like to be done as soon as possible so wanted to leave the radiator and cowl together. This means leaving the fan off though.
Can it be done? Of only tried for a week or so until a new pump comes as I'm fitting another used one
Posted 22 May 2012 - 08:42 PM
Posted 22 May 2012 - 08:45 PM
Still, if someone feels the risk of a 'cooked' engine is worth it then fine.
Posted 22 May 2012 - 08:49 PM
Posted 22 May 2012 - 08:53 PM
Posted 22 May 2012 - 09:03 PM
Posted 22 May 2012 - 09:04 PM
Posted 22 May 2012 - 09:07 PM
I have a 2 core rad, and 74 degree thermostat, and only just stay on the normal, under average driving conditions, as soon I hit traffic the aux electric fan comes on to stop the temperature rising, I'd be in serious trouble without both fans!
Edited by Midas Mk1, 22 May 2012 - 09:08 PM.
Posted 22 May 2012 - 09:09 PM
An electric fan is not intended to have a 100% duty cycle and if it fails you will either be sitting beside the road awaiting a tow and possibly have a 'cooked' engine.
Why on earth would anyone want to take that risk? The car was designed to have a belt-driven fan for good reason.
Posted 22 May 2012 - 09:31 PM
Posted 22 May 2012 - 09:35 PM
Posted 22 May 2012 - 09:43 PM
Posted 22 May 2012 - 09:48 PM
on a front mounted rad the fan only works when the car isn't moving, with a minis side mounted rad the fan will need to be on all the time
Posted 22 May 2012 - 10:58 PM
I have heard of people removing the fan and just running an electric on for when the temperature starts to rise. So that there is less drain on the engines power and it apparently 'only works until speeds of abou 20mph, after that just gets in the way"
