Any Options?
4 replies to this topic
#1 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 May 2012 - 02:04 PM
Removed my huge wheel arches to find the below - paint work is good, no rust, just holes. Apart from getting them filled up, then re-painted, which would probably mean most of the car, has anyone come up with something less expensive / creative?!
The other side and rears are the same, ie original holes, then additional holes for the bigger arches, paintwork is perfect.Attached File  IMG_3783.JPG   52.7K   26 downloads
I dont want to fit any arches at all, as I will be going with 4.5 inch wheels.
Edited by maccers, 24 May 2012 - 02:05 PM.
#2 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 24 May 2012 - 02:55 PM
Stickerbomb it. There is no cheap option to be honest, unless the color is easily matched when applied with a brush, then do the process as you described it.
#3 jaydee
jaydee
  • 8,565 posts
Posted 24 May 2012 - 03:04 PM
I'm in the same process..best option would be welding the holes and re-paint..cheapest is sticker bombing, as above.
Fit the chrome trim over the lip, it will took away some attention from the little imperfections. :)
#4 03jkirk
03jkirk
  • 465 posts
Posted 24 May 2012 - 03:35 PM
have the wings been cut to accomodate the arches??? if they have to make it look right u may have to resort to new wings and a-panels
#5 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 24 May 2012 - 04:49 PM
From what I can tell, the wings look un-cut, ie they have the folded lip part that looks like its been done on a press vs being re-created with mole grips. The wheels on the car were 5.5 * 13's. I suspected they had been cut too, but I think if you go to 6 inch wide you need to start snipping away. The ride height was always set normal to high on the hi-los.
Am probably going to get them welded and whole side's and front re-painted. May as well do it correctly. Stickerbomb - made me laugh! never heard of that before!!
