Engine Oil Drain Plug
11 replies to this topic
#1 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 24 May 2012 - 07:47 PM
Was all up for changing my engine oil and filter tonight and couldn't get the old drain plug off because it was so big! Annoying because the new one I have from mini spares is smaller (21mm? Can't remember) and I have the socket for it.
Anyone got any idea if some minis used a plug with a larger end? Think the one on the car is about 25mm and the biggest socket/spanner I have is 24 :( Also don't have an adjustable spanner big enough.
`91 Mayfair by the way.
#2 Cooperman
  • 23,326 posts
Posted 24 May 2012 - 07:51 PM
The sump plug is 15/16" AF spanner size. Forget about metric sizes, the classic Mini is almost all UNF/UNC thread sizes and a set of Imperial sizes is a must.
#3 MiniLuke
MiniLuke
  • 1,205 posts
Posted 24 May 2012 - 07:52 PM
I had this. Tuned out someone had stripped the thread and retapped to a larger size, rendering my new plug redundant.
#4 lewBlew
lewBlew
  • 1,238 posts
Posted 24 May 2012 - 08:09 PM
B****r! Might need a different plug, difficult to know without getting it off, then can't drive the car to get one!
#5 lewBlew
lewBlew
  • 1,238 posts
Posted 24 May 2012 - 08:15 PM
Oh and I have got imperial as well, just they stop at a smaller size than my metrics.
#6 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 24 May 2012 - 08:19 PM
Classic! been tampered with. My sump plug is a hex key
#7 lewBlew
lewBlew
  • 1,238 posts
Posted 24 May 2012 - 08:29 PM
Well literally classic haha. Frustrating as apart from the wheels and that it's totally standard. Grrrrr! Last owner was a bodger though judging by the underside so that fits.
#8 MiniLuke
MiniLuke
  • 1,205 posts
Posted 24 May 2012 - 08:31 PM
Might just need a new copper washer really though. Just get a selection of sizes prepared.
#9 liirge
liirge
  • 4,097 posts
Posted 24 May 2012 - 09:49 PM
unless there's a chip on the mating face...no copper washer sorts that.. =]
#10 lewBlew
lewBlew
  • 1,238 posts
Posted 25 May 2012 - 11:07 AM
Right... had a little measure and the one that's on there is about 1" so only a tiny bit bigger than the standard plug, but still too big for my socket set. What are the chances the thread is the same size or does it not work like that? i.e. thread size relative to head?
I have a new copper washer so may just re-use the same plug (although loathe to do so).
#11 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 25 May 2012 - 12:07 PM
Why have you bought a new plug? Just buy a proper 15/16" AF socket, remove the plug, replace the copper washer, and put the original plug back in - they are re-useable...
#12 lewBlew
lewBlew
  • 1,238 posts
Posted 25 May 2012 - 12:10 PM
A 15/16" socket won't fit as the plug in there is too large, and I felt like putting a new one in since I've never had it out before!
