Oil Leak From Engine Steady Hole?
4 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 May 2012 - 08:34 PM
Had my mini at a good garage to get the ball joints replaced, (wasnt up for it myself).
The car developed a n oil leak, which i thought must be from the gear linkage seal, the car had sat all winter.
I remember at my last MOT I was under the car and saw what i though was a bolt missing from the rear lower engine steady bracket. It did look a tad oily though.I totally disregarded this (stupidly) as I couldn't have dropped a bolt! I mean the bracket has never been touched.
Went to pick the car up today and was told i was indeed missing a bolt on the engine steady bracket.
Is that the right, can that case an oil leak?
If so you learn something new about these cars every day. :mmkay:
oh and god knows how the bolt has undone itself.
#2 oltonlad
oltonlad
  • 2,401 posts
Posted 24 May 2012 - 08:50 PM
where is the rear engine bracket attached to on the engine?, if its the diff cover then thats probably whats leaking.
#3 MiniLuke
MiniLuke
  • 1,205 posts
Posted 24 May 2012 - 08:53 PM
Are you sure it's not snapped off? Being a bolt holding a bracket, and subject to force on the engine rocking?
#4 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 May 2012 - 08:54 PM
Wait it might a engine to front steady. I will need to check. Either way was definitely a bolt missing with oil coming from the hole.
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 May 2012 - 08:55 PM
No as they just replaced it with a new bolt, they said maybe the spring washer hadnt been fitted previously (this i cannot confirm).
