Fuel Pressure
Posted 26 May 2012 - 09:46 AM
Cheers james
Posted 26 May 2012 - 10:37 AM
Posted 26 May 2012 - 12:18 PM
Cheers james
Posted 26 May 2012 - 01:10 PM
Twin HS2s normally run at 2-3 PSI (at the carbs). Their fuel consumption is way below what every Facet pump I have seen can deliver.
Consider some quick and boring math. According to the Facet literature for the "top" pumps
(http://www.facet-pur... flyer 2011.pdf)
These flow 20 to 45 gallons (U.S.) per hour. Now consider you pushing your engine to its max. Maybe your fuel mileage drops to 8 miles per gallon (U.S.) At 100 miles per hour you would need to pump 12.5 gallons per hour... well below the smallest Facet pump's capability.
That begs the question how/where did you mount the Facet. If you mount it high and the pump has to suck the fuel "up" that will make it work harder and effectively lower its capabilities.
Posted 26 May 2012 - 04:14 PM
Posted 26 May 2012 - 05:22 PM
Why are you wanting to reduce the power from your engine ? The HIF 44 is FAR better than tiny twin HS2 carbs !!
Im wanting to have the option of running either carb set up, twins look the dogs and sound nice too!!!!
Posted 26 May 2012 - 07:46 PM
Posted 28 May 2012 - 04:16 PM
Dear oh dear....
I dont really know what the problem is running twin hs2's..... I do believe they used them on the 1275 cooper s? So why is it stupid using them on my 1275? Can you please enlighten me?
Cheers james
Posted 28 May 2012 - 10:07 PM
Returning to the fuel pump issue though... the twin HS2 carbs were supplied more than well enough by the SU electric pump. Both the electric and mechanical SU pumps supply 2-3 PSI.
Posted 29 May 2012 - 07:06 AM
Cheers for the heads up
James
Posted 29 May 2012 - 12:11 PM
Posted 29 May 2012 - 04:50 PM
Cheers james
Posted 28 July 2013 - 04:54 PM
Hi everyone, i know this is an old topic but need something clarified, i had a 67mm filter king regulator running with my hif44 but changed it to a 87mm v8 model filter king one, had some flooding problems which ive put down to high psi, had to put a new spring in the regulator as it wouldnt drop down past 3psi (specs say it will drop down to 1-1.5psi) got it at 2psi now so hopefully will be fine now, but my question is, that it is a high flow model for v8 engines (the only difference i can see from the standard 87mm regulator is that it has bigger pipe tail ends which i have reduced for 6mm bore pipes) will high flow of fuel cause a problem or is it just high pressure thats causing my problems? p.s. only bought it because it was black and could fit the blue and red annodised fuel line fittings i negated the saying if its broke dont fix it! lol. any help would be ace.
