Has Anybody Done A Twin Su Turbo Set Up? How Did It Go?
11 replies to this topic
#1 MyZeemaxMiniTurbo
MyZeemaxMiniTurbo
  • 55 posts
  • Local Club: Leamington spa mini massive
Posted 26 May 2012 - 12:04 PM
just a thought, it obviously could be done......but has anyone done it? how did they get on? how did the car run?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 May 2012 - 01:33 PM
with a turbo set up you have air forced into the engine, why would you need 2 carbs ?
#3 MyZeemaxMiniTurbo
MyZeemaxMiniTurbo
  • 55 posts
Posted 26 May 2012 - 02:12 PM
spread the fuel across cylinders more efficiently?
#4 James_1
James_1
  • 253 posts
Posted 26 May 2012 - 02:54 PM
It has been done... (Janspeed SD1 Twin-Turbo)
With a turbo because the inlet is pressurised the problems with uneven distribution of fuel is less of a problem than with a N/A setup so a single carb is not too bad.
#5 Magic jason
Magic jason
  • 522 posts
Posted 26 May 2012 - 03:14 PM
its alright on a nice big engine like that, but surely all mini engines are too small :L
#6 03jkirk
03jkirk
  • 465 posts
Posted 26 May 2012 - 08:15 PM
cant do twin carb turbo with anything like HS2 or HS4 as they are not sealed units like the turbo HIF44 and a twin HIF44 (if could source a carb with mirrored controls) would be completely pointless as with a good turbo set up the HIF44 can be used to produce more power than many components on the mini can withstand so it doesnt really restirct the engine.
#7 Ethel
  • 26,074 posts
Posted 26 May 2012 - 08:55 PM
That's some setup in James's photo! Looks like a twin turbo, suck through system :unsure:
More like two separate installations, they only share that huge tin T (air filter?). There's that Janspeed kit that features in DV's book, it had a twin choke Dellorto pinched off the Turbo Esprit - if that isn't over carbing, I dunno what.....
#8 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 27 May 2012 - 08:32 AM
It's only a 40, so hardly overcarbed ! lol
#9 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 27 May 2012 - 09:04 AM
http://www.turbo-min...3373/52548.html ;D
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 27 May 2012 - 03:18 PM
Lots more acceleration to be had from twin boosted SU's. No more power though.
AC
#11 Wil_h
Wil_h
  • 3,244 posts
Posted 29 May 2012 - 02:07 PM
AC
Whay would this be? You are goverened by the flow of the turbo, not any carburation; unless you have reached the limits of what you have. The HIF44 has been shown to make well over 200 bananas, so why do you need any more.
Thre is no real worry with the carbs leaking, the SU is quite well sealed. It may be worth putting seals on the spindle if possible though.
#12 James_1
James_1
  • 253 posts
Posted 09 June 2012 - 04:44 PM
Yeah, I couldn't find the photos of it in blow thro form but it was run in both forms. It's the Janspeed Twin-Turbo SD1. I don't know what happened to the car but it was a real monster at the time. The engine sold on eBay a few months ago, in blow thro form again IIRC.
