Windows
5 replies to this topic
#1 Suzzer16
Suzzer16
    Starting My Mini Up
  • 4 posts
Posted 27 May 2012 - 09:04 AM
Hey
I tried looking around for anything about windows but couldn't find anything so I started a new topic...
I've got a '95 Rover Mini Limited Edition Sidewalk...my nearside and offside windows don't roll down all the way. I don't know if there's a simple solution to this or if it's supposed to be like this? Just wondering if anyone else has had this problem and how they fixed it. Any information will be helpful. I'm new to the Mini scene so I want to try and sort the simple things out on it myself.
Thanks to anyone who can help =)
Suz
#2 MGBailey007
MGBailey007
  • Validating
  • 725 posts
  • Local Club: North West Mini Club
Posted 27 May 2012 - 09:29 AM
if the screws for the door handles are too long then the screw will stop the window going down, unscrew the door handle and try wind it down see if it works, if not unscrew something else on the door card until you find the right one, that should sort it out, then just use washers on the screws or get shorter ones
Edited by MGBailey007, 27 May 2012 - 09:30 AM.
#3 Suzzer16
Suzzer16
    Starting My Mini Up
  • 4 posts
Posted 27 May 2012 - 06:35 PM
Thanks for the advice I'll try that out and let you know if it works! =)
#4 Suzzer16
Suzzer16
    Starting My Mini Up
  • 4 posts
Posted 06 June 2012 - 02:19 PM
Hey,
I have tried that but it didn't seem to work...is there anything else I could try?
#5 The Principal
The Principal
  • 763 posts
Posted 06 June 2012 - 05:25 PM
check the scissor mechanisms in the doors have they come adrift or need greasing? or do you have speakers in the door cards fouling the windows? as above check the windows are free to travel the full distance if so check the mechanism
#6 HafMan
HafMan
  • 383 posts
Posted 06 June 2012 - 05:36 PM
I have this problem and when i checked the strip that the metal is attached to was severly rusted so I suspect this is the cause.
Mine is a 1997 mini so yours is probably also affected.
