How Much To Bore Out 998
21 replies to this topic
#1 SteveeR
SteveeR
  • 44 posts
  • Local Club: Hilltop Minis
Posted 27 May 2012 - 09:01 PM
Alright lads
At the moment I have a 998 stage 1 engine and im looking to bore it out or go up through the stages. I was wondering what the cheapest method of getting the most of my engine is as I cant find much info as I dont know where to look! Im looking to spend about £500. Also, would it be cheaper to buy a 1275 and bore it to a 1380? One last thing as well, how hard is it to bore a 1275 into a 1380 yourself?
Cheers guys
#2 oltonlad
oltonlad
  • 2,401 posts
Posted 27 May 2012 - 09:08 PM
you have got no chance of building a 998 or a 1275 for £500........even if you used second hand bits you would be looking at the wrong side of £800 at least.......
a decent set of pistons are £250 on their own, plus the cam/followers, machine work, cylinder head, new bearings etc etc etc
and if you are a young driver then no-one will insure you on a 1380 anyway.
Edited by oltonlad, 27 May 2012 - 09:09 PM.
#3 SteveeR
SteveeR
  • 44 posts
Posted 27 May 2012 - 09:12 PM
If I kept the 998, I would only want to bore it to a 1100-1200.
I meant changing the engine to a 1275, then boring that to 1380.
#4 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 27 May 2012 - 09:16 PM
I do have to ask, how would you do it yourself?
It's easy, if you have a boring and honing machine, which unless you work at a machine shop, is very unlikely.
No point in over-boring an engine in the pursuit of power if you are on a budget, spend it on a nice cylinder head assuming the engine's not worn out and in need of a re-bore. Also, a 1275 is going to be a better base than a 998 because it's more powerful standard.
#5 oltonlad
oltonlad
  • 2,401 posts
Posted 27 May 2012 - 09:17 PM
you can only bore a 998 out to 1080 as far as i'm aware, and even then the bores are getting a bit thin.
#6 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 27 May 2012 - 09:19 PM
I bored my 998 to a 1030 using sandpaper :shifty:
#7 oltonlad
oltonlad
  • 2,401 posts
a 1380 engine will only be any good if it is built properly, i've known well built 1293 engines wipe the floor with poorly built 1380's that were built on a budget.
#8 oltonlad
oltonlad
  • 2,401 posts
Posted 27 May 2012 - 09:20 PM
hahahahahahahahahaha :ohno: ............... :lol:
#9 SteveeR
SteveeR
  • 44 posts
@Luke
I have a large garage and my dad has a good understanding of Minis as he has had over 10, but hes not great with engines. And I have two garages within a couple of miles which I am good friends with the owners so could use thier equipment.
I was really looking to bore a 998 to a 1180 is it? Or get a 1275 and bore it to a 1308, and to a 1380cc later.
#10 Ryang556
Ryang556
  • 2,747 posts
Posted 27 May 2012 - 09:21 PM
The bores went a bit oval using sand paper but just makes her sound cammed... :lol:
#11 oltonlad
oltonlad
  • 2,401 posts
there was a guy on here that was going to increase the capacity of his engine by dishing the pistons..............lmao
#12 oltonlad
oltonlad
  • 2,401 posts
Posted 27 May 2012 - 09:22 PM
@Luke
you will never get a 998 to go to 1180...............i think that you meant 1080
#13 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 27 May 2012 - 09:23 PM
I spent ages explaining why that doesn't work then Shifty hid it >_<
#14 SteveeR
SteveeR
  • 44 posts
@Luke
Yeah, 1080, sorry, miss-typed. Keep forgetting the numbers
#15 oltonlad
oltonlad
  • 2,401 posts
Posted 27 May 2012 - 09:26 PM
just get a 1098 engine, put a 266 cam in it with a decent head and you will be seeing 65-75bhp with good torque.........thats what i did and its a great engine.
