1275 Engine Build Advice, Please :)
Posted 29 May 2012 - 10:13 AM
First ill explain how this has all come about. In my clubman estate (see my thread in my signature) I have the original low mileage 1098 engine. A cracking, very reliable unit. With just me in it feels nippy around town. However on the open road the final drive results in the engine revving too high, a comfortable and economical speed being around 50-55mph. Disregarding the engine noise the shell has been comfortably to 80, above that is a little hairy
Currently I am interested in taking Noddy (my mini) to the Alps and driving around the Riviera into Monte Carlo ect. For this Noddy would need more go. And be able to cruise nearer 70 mph.
So, here came about the engine build I am currently doing.
In a nut shell the engine needs to be a sort of “sports tourer” 80bhp and similar torque, region. But it has to be reliable.
These are what I already have for this build:
90s cooper A+ 1275 engine – going to need a rebore to 1293 & crank regind.
Gearbox – going to be a guesswork’s rebuild, 3.1 final drive (a compromise between top speed and acceleration)
1.5 roller tip rockers – impulse buy, not sure if they will be used
Hiff 44 carb – rebuilding this currently
It will have a full maniflow exhaust too (not yet purchased)
The normal freeflow inlet and airfilter.
Now for my questions
Cam shaft – what do you recommend? I still want a smooth idle, and usable power without having to scream the engine, I have the option of the 1.5 roller rockers too.
Cylinder head – to achieve the results I am after would a stage 3 be overkill? Just porting the standard head be enough?
Duplex timing gear – necessary?
Cros pin diff – necessary? Or will the hardened guesworks one be sufficient?
I am sure more questions will follow!
Thanks in advance,
Matt
Posted 29 May 2012 - 10:20 AM
266 with 1.5 rockers should be ok.
stage 2 head, double valve springs
duplex not absolutely nessecary, but might aswell if your getting a adjustable set to time the cam correctly.
best person to ask would be GuessWorks i guess?
Posted 29 May 2012 - 12:25 PM
Posted 29 May 2012 - 12:40 PM
I prefer cams with low-end torque rather than high-end power. That will equate more to acceleration than the ability to drive at high-speed. Therefore, the 266 cam or the SW5 might be nice along with changing the final drive to give you a bit taller gearing for highway cruising. Duplex timing gears... why not? 1.5 rockers? They are expensive and they transfer higher loads onto the tappets and cam lobes. Personally I would retain the regular rockers but it is your choice.
I would be interested in what others tell you about x-pin diffs. I am considering one myself.
Posted 29 May 2012 - 01:08 PM
The 3.1:1 FDR will be fine and a slightly lightened flywheel would be good too.
Think about a better distributor, like an Aldon 'Yellow'.
With regard to X-pin diff, I always use one in my rally cars, but for road cars I normally just buy a Mini Spares competition spec one.
Posted 29 May 2012 - 01:33 PM
with regards to how the car is going to be used, it will be used for fun and holidays. But be able have a bit of go if I feel like it. However the tourque, reliabilty and cruising speed are what I am ultimatly after. With that some extra power will be a by product. Plus anything will feel better than the standard 1098 which is in there currently.
Cost is not a major issue as this is my big splash out before saving for a house. I want to make sure what I do is 100% and will give the results I am after.
I have been doing alot of thinking about the final drive, my best friend has a sports pack, and that did cruise nicely, I am just wanting to retain some livelyness for the twisty bits. However if the engine spec gives the extra tourque to pull the longer gears then it would make sense to be able to cruise at a higher speed! - this is what i am most undecided on currently!
Posted 29 May 2012 - 06:24 PM
Posted 29 May 2012 - 07:17 PM
Posted 30 May 2012 - 09:41 AM
Edited by matthew_leech, 30 May 2012 - 09:42 AM.
Posted 30 May 2012 - 09:42 AM
Posted 30 May 2012 - 09:48 AM
cooperman, you say with the metro head 12g940, that there will be clearance issues? what would these be and how would you suggest over coming them?
On the 1098 it will need pocketing or other work-around, but on overbored 1275s cant be a problem as 940 is a 1275 head
Posted 30 May 2012 - 09:51 AM
all the work is going on the 1275, just keeping my 1098 in as it is for now!
I always keep everything original from the car, just incase i ever want to revert back to standard!
Thanks again!
Posted 30 May 2012 - 09:57 AM
The head you need is the 12G940 MG Metro head with the 35.6 mm inlet valves and, ideally, 30.5 mm exhaust valves, then cleaned up and gas-flowed a bit.
I built a 'blueprinted' 1275 engine for a rally Mini which had to have a 'standard' engine. It was a 1990 Cooper 1275 bored out to 1330 cc (max allowed under trhe regs. It had MG Metro Cam, MG metro head which was just 'cleaned-up' a bit, Aldon dizzy, cleaned up inlet manifold with HIF44 carb, Duplex timing chain, RC40 twin-box exhaust, centre-main strap, and a very accurate build in terms of cam-timing and parts matching. It gave 84 bhp at about 5700 rpm and was super to drive. It had a 3.44 final drive and did a timed 0 - 60 in 10.2 seconds in full rally trim (2 spare wheels, extra equipment, etc).
Posted 30 May 2012 - 10:06 AM
Your engine you built there sounds like a very similar spec to what I am aiming for. I am really impressed with that hp ouput from that spec, I hope my build will achive that kind of output.
You mention the accurate build, I understand the cam timing, but could you expand on where parts were matched, and how this was done?
Thanks again!
Posted 30 May 2012 - 10:27 AM
Although not strictly legal within the regulations for the rallying I was doing, I did slightly re-shape the head chambers to de-shroud the valves a bit and I removed the nasty step around the valve seats. I also slightly 'improved' the inlet & exhaust throats but left the surface with a roughish finish to keep it looking standard, especially where I ground some off the very intrusive valve guide bosses. I did actually shorten the valve guides by about 3 mm thus reducing their intrusion into the inlet & ex. tracts.
Inside the carb I did a bit of subtle improvement like removing a bit from the butterfly spindle and knife.edging the butterfly leading face.
I changed the piston rings for a set of 'Total-Seal' rings made by a company in Phoenix, Arizona. They have a 'gapless' 2nd ring and are fantastic. My friends in the USA who race aeroplanes use these type of rings in their race engines.
At the carb inlet I used a K & N filter with a 'stub-stack'.
Exhaust manifold had to be the standard 1990 Cooper twin down pipe set-up and I fitted a Maniflow twin-box centre-exit system to keep it quiet enough for rallying.
I changed the fan for a 6-blade export steel one.
Distributor was Aldon 'Yellow'.
'Blue-printing' is very labour intensive, but can make such a difference to final output. That is why well-built engines done by the engine-build companies are so expensive. A good blue-printed engine can give power similar to cheaply-built (thrown-together!) more highly-modified engines , but will give better road-manners and much increased reliability.
I hope all this helps you with yours.
