Driveshaft Balls / Recon?
8 replies to this topic
#1 mini*mad
mini*mad
  • 423 posts
Posted 30 May 2012 - 02:42 PM
as it sounds im having problems with my balls
they just wont stay in!
on a serious note though whenever i remove my driveshaft the steel balls fall out
it seems they are abit to small for the hole and as ive found some horrific bodges on my car i think this may be another!
does anyone know how to recon this part of the driveshaft or what to do?
its on both sides and some stay in but a few pop out and can be placed back in by hand!
can provide pics at around 9:10pm tonight as im at work
#2 jaydee
jaydee
  • 8,565 posts
Posted 30 May 2012 - 03:03 PM
The race with the balls its part of the pot joint, not the shaft.
Remove the race from the driveshaft and fit new pot joints.
Actually, fit new pot joints to the gearbx output shafts first, then slide the drivashafts in the pot joints, otherwise you wont be able to pass them through the subframe hole.
#3 mini*mad
mini*mad
  • 423 posts
Posted 30 May 2012 - 03:09 PM
the pot joints are fixed to my gearbox and the balls are in my driveshaft sort of covered by the rubber gaiter
which you fasten over the gearbox pot joints when you slide the driveshaft in?
#4 mini*mad
mini*mad
  • 423 posts
Posted 30 May 2012 - 03:15 PM
or are there pot joints on both sides :S *DRIVESHAFT NOOB*
as the driveshaft is inserted into the gearbox pot like join id presume it wasnt called a pot as its a male piece lol
Thanks!
#5 jaydee
jaydee
  • 8,565 posts
Posted 30 May 2012 - 03:22 PM
Pull whats rest of the joint out of the gearbox, and remove the race from the driveshaft. The driveshaft end is splined and goes into the pot joint. The pot joint is splined and goes in the gearbox output..pot is female (avoid sexual comments! LOL)
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 30 May 2012 - 03:23 PM
You have:
Drive shaft-pot joint-diff output shaft-diff-diff output shaft-pot joint-drive shaft
The pot joint has two main parts, the big POT that the driveshaft with the balls go into, and then you have a cage with balls in, that slides onto the end of the drive shaft. Have a look on minispares at what the parts look like, new, clean and grease free...should make more sense then!
Hope this helps
#7 mini*mad
mini*mad
  • 423 posts
Posted 30 May 2012 - 03:36 PM
ahh so i need the potjoint with the cage & balls as ive always had trouble getting all the balls and driveshaft in the gearbox pot
O_O :lol:
#8 jaydee
jaydee
  • 8,565 posts
Posted 30 May 2012 - 03:44 PM
The pot joint comes complete greased and assembled. The race and the balls are matched parts, imagine it like a CV joint that rotate on a fixed axle.
#9 mini*mad
mini*mad
  • 423 posts
Posted 30 May 2012 - 04:08 PM
ahh ok, well as its all apart when changing hub bearing i may aswell get the pot joints ordered from moss europe :)Thanks guys
