Rear Shock Upper Mount
22 replies to this topic
#1 Wrenchpuller
Wrenchpuller
  • 35 posts
Posted 31 May 2012 - 11:57 PM
Hi everyone,
To do work on the rear suspension, I once again have to remove the gas tank. 73 Mini 1000
Not a job I enjoy. I know I have seen on the forum, photos and a description of how to cut an access hole in rear panel. But I cannot find the posting. Would someone please point me towards it ? I figure if I cut and cover the access hole this time then I will never have any reason to pull the tank, Having said that watch the thing spring a leak on me sometime.
Cheers and thanks Ric
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 June 2012 - 06:19 AM
in the rear seat back rest just about the wheel arch
#3 david@skeggyminis
david@skeggyminis
  • 352 posts
Posted 01 June 2012 - 07:49 AM
by the time you get in the back and remove the seat you could have the tank unbolted and moved to the side to get to the shock top
#4 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 01 June 2012 - 07:54 AM
I think it was Cooperman who described it. But isnt has car a rally car, requiring a lot of maintenance and thus regular access to the rear dampener.
The tank takes all of ten minutes to move
#5 Wrenchpuller
Wrenchpuller
  • 35 posts
Posted 01 June 2012 - 04:59 PM
Many thanks to all for the replies, and info. Just seems to be every time I have to remove the tank, I have just filled it. Removal is not such a pain, except the 2 bolts through the rear parcel shelf. And the fact I have just topped the tank up. Dislike messing around pumping it into gas cans. Oh well, job for tomorrow, going to fit coil springs to the 4 corners.
Cheers Ric
#6 Cerberus
Cerberus
  • 989 posts
Posted 01 June 2012 - 10:07 PM
What are these two bolts in the parcel shelf? Whenever I'm removing the tank, I just undo the bolt at the bottom that holds the strap on, and then just pull the tank out carefully, and the strap just moves/bends with it.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 01 June 2012 - 10:28 PM
Coil springs ?? Not a great idea.... You would never do that anyway working through a flap in the rear panel - it's ok for access to the top damper nut -but for modifying turrets to take coil springs you will need full access. Be sure to remove the battery before touching the fuel tank!
#8 samsfern
samsfern
  • 5,243 posts
Posted 01 June 2012 - 10:52 PM
I think he means coilovers.
You can get the rear ones with the offset top mount bolt, thus not needing to modify the Turrets, but im not keen on the idea of those type.
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 01 June 2012 - 11:08 PM
The shell is not designed to take loads like that - BMC fitted a subframe for good reason....... And yes - many many moons ago I removed most of the rear subby and formed turrets to take coil springs with suitable bracing to the rear seat back. But this was an ultra lightweight autocross car - not a road car which may be loaded up with fat mates!!
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 01 June 2012 - 11:58 PM
Or fat lasses! They're always more greatful tho!
#11 Wrenchpuller
Wrenchpuller
  • 35 posts
Posted 02 June 2012 - 04:46 AM
Whoa guys, don't kick me so hard..............LOL
cerberus...It's a North American Mk3 (Canada) the 2 bolts through parcel shelf hold and attach a fuel tank restrraing bracket
bmcecosse.....It is a coil spring conversion (from Rubber) Still have to drop LHR shock to fit........Any reason you want to give as to why the coil conversion is no good ?? Any input will be great..thanks
samafern.....No not coil over, as said above...coil conversiom from rubber
bmcecosse....As said not coil over , so shell load n/a
#12 Cooperman
  • 23,364 posts
Posted 02 June 2012 - 11:12 AM
Here is a photo shaowing exactly where to cut the rectangular hole in the rear seat panel.Make up the cover plate about 3/4" bigger all round and seal it with bathroom sealant when fitting it.
I hope this helps.
#13 samsfern
samsfern
  • 5,243 posts
Posted 02 June 2012 - 11:24 AM
:lol: in my 3 and half years of driving, ive never actually had the pleasure of transporting a "large turkey", dont think im missing out on much though :lol:
#14 Wrenchpuller
Wrenchpuller
  • 35 posts
Posted 02 June 2012 - 02:33 PM
Thanks Cooperman,
That is "Magic". I plan on cutting that while I have the gas tank out, Will cover wiith a plate and self tappers, and sealant.
If only our tanks were held in place by just the strap clamp, but alas there are 2 restraining brackets as well (upper and lower).
Would be tempted to leave them off, but the insurance company would leap at the excuse to refuse payment if ever needed.
Thanks for the info and pic
Cheers Ric
#15 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 June 2012 - 05:00 PM
BMC designed the Mini with clever progressive rate rubber cone springs - I don't see any reason to go away from that for a road car........ and what does your insurance co think about the idea. As for 'coil overs' - where do you think the suspension loads are going - if not into that top damper mount ?? Which on a 1973 car may not now be in tip top condition??
