Cooper S Peg Drive Oil Pump
Posted 01 June 2012 - 05:20 PM
Posted 06 June 2012 - 03:23 PM
Posted 08 June 2012 - 09:06 PM
Posted 09 June 2012 - 06:58 PM
Posted 02 July 2012 - 07:52 PM
Posted 03 July 2012 - 08:54 PM
Posted 03 July 2012 - 09:10 PM
Posted 03 July 2012 - 09:13 PM
Posted 03 July 2012 - 09:16 PM
Posted 04 July 2012 - 06:32 PM
Posted 05 July 2012 - 12:46 PM
Do you mind if I ask why you would want a used oil pump?
Posted 05 July 2012 - 04:10 PM
Posted 05 July 2012 - 05:01 PM
I am trying to Trying to run a special tuning 649 cam in my 1275 engine. The cam was designed when the cooper s engines were still in production, and so were the oil pumps. As now they are not being made, I need one. My plan is to get your pump, knock out the pin drive bit and install it inside another oil pump. It is doable, I have spoken to someone who has done it, I just need a cooper a oil pump
Posted 05 July 2012 - 07:25 PM
I think the adapter 5portsrock is taking about is for fitting a slot drive pump to a spider drive camshaft but it might be worth doing a bit of searching for more info.
If you still want to do the pin drive conversion let me know. Meanwhile I will have a closer look at the pump to make sure the drive pin is OK.
Posted 05 July 2012 - 08:21 PM
