1992 Cooper Ecu
7 replies to this topic
#1 BennMurray
BennMurray
  • 30 posts
Posted 02 June 2012 - 01:13 PM
In the process of removing the engine and I'm wanting to disconnect the ecu from the loom to allow for more room, but I'm wandering if as soon as I unplug the ecu will it "lock"? As i know this happens with some of the modern types
#2 BennMurray
BennMurray
  • 30 posts
Posted 02 June 2012 - 04:48 PM
any ideas??
#3 BennMurray
BennMurray
  • 30 posts
Posted 02 June 2012 - 08:40 PM
bump....
#4 BennMurray
BennMurray
  • 30 posts
Posted 03 June 2012 - 10:28 PM
suprised no1 has an answer to this!
#5 BennMurray
BennMurray
  • 30 posts
Posted 04 June 2012 - 03:27 PM
bump again..
#6 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 04 June 2012 - 03:37 PM
it doesnt on my m8s racecar but he dont have radios immbilisers etc
#7 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 04 June 2012 - 04:40 PM
Since you are not getting many answers, I will give it a shot based on my limited experience. Since you have a 1992 I believe that you have an early two connector ECU. I am not sure what the number on it would be, however it is probably MNE10092. The alarm system should work like the the early version of the single connector ECU for Coopers MNE101070 (1993- 1994). That is the one I have. The alarm does not disable the ECU. It only disables the starter relay. You should be able to push start the car even with the alarm on. So your ECU should not "lock" when disconnected.
The later Cooper ECU's (1995? on) MNE101170 are interconnected with the alarm. The alarm must send a 4 bit code ( I believe) as it is turned off to activate the ECU. This type of ECU can get out of sync with the alarm an then it will not operate. Additionally, the alarm and the ECU must be matched if either is replaced.
I hope that helps,
Ivan
#8 icklemini
icklemini
  • 2,982 posts
Posted 05 June 2012 - 11:05 AM
disconnect battery, remove ecu, etc - re-fit and enjoy!
in short: no it wont 'lock'. :)
