Accuspark Or Aldon
16 replies to this topic
#1 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 04 June 2012 - 05:54 PM
is there a reason why the accuspark is cheaper?
who has what on there cars?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 June 2012 - 06:10 PM
just fitted the britpart kit for 16.63 inc delivery.
#3 2-alex-2
2-alex-2
  • 480 posts
  • Local Club: SouthWalesMini club
Posted 04 June 2012 - 06:14 PM
i have an accuspark on mine no problems yet seem good and easy to fit like the rest of them
Edited by 2-alex-2, 04 June 2012 - 06:15 PM.
#4 leroy26
leroy26
  • 2,239 posts
Posted 04 June 2012 - 06:20 PM
and its black wire to - on the coil and no other wires connected to coil and red wire to ignition switch yes?
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,142 posts
  • Name: Sean
Posted 04 June 2012 - 06:24 PM
Depends on the car, if you've got ballasted ignition then you need a new feed to the coil.
I've got both aldon and accuspark and don't see a difference.
#6 leroy26
leroy26
  • 2,239 posts
Posted 04 June 2012 - 06:27 PM
yeah its ballested, so find a spare connection on the ignition?
#7 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 June 2012 - 06:31 PM
For ballest ignition setup.
The elec ignition module requires 12v source. Dont touch the coil wiring!
If you have ballast setup (can be found out by looking at coil, you will have a white/pink and white/yellow) then you need to take a 12v source to power the module. This can be done by taking a feed from the top (4 fusebox, std lucas type) fuse, on the left hand side as you look at it.
Connect the black wire from the module to the old points wire or direct to coil negative.
#8 leroy26
leroy26
  • 2,239 posts
Posted 04 June 2012 - 06:33 PM
leaving the pink/white wire on the coil + aswell?
#9 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 June 2012 - 06:35 PM
dont touch the coil wiring (other than adding the black wire from elec ign to coil negative if required)
just connect the red (positive) wire on the electronic ignition module direct to the fusebox for a 12v (switched live, aka on with ignition key which is fuse 1)
#10 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 04 June 2012 - 06:36 PM
Yeah, jordies right, I've been to the pub this afternoon!!
Just wire the + wire(red) to a switched live.
#11 leroy26
leroy26
  • 2,239 posts
Posted 04 June 2012 - 06:37 PM
sweet! thanks
it may be some help to someone else too
#12 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 June 2012 - 06:41 PM
Cheapest source I can personally find for the britpart kit is
http://www.paddocksp...tronic-kit.html
Now its a land rover site, those of you who "know" these kits fit both mini and land rover. They come with basic instructions which dont relate to any vehicle in particular. Its basically remove points and condensor, fit electronic module in place, magnetic pickup/rotor arm and wire up.
worked out at £16.63 for me eariler this week.
#13 waddle
waddle
  • 536 posts
Posted 12 June 2012 - 04:36 PM
was the one from paddocks ok then, or did it need any changed
#14 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 12 June 2012 - 05:35 PM
it was fine. i had to remove a pin from my dizzy plate because it was an older pre a+ dizzy.
#15 waddle
waddle
  • 536 posts
Posted 13 June 2012 - 10:14 PM
ah gdgd i have one on the way, just wondering how i can tell if my coil is balisted or not? i have a 12 volts on the wire that goes into the +ve side if that helps?
