Baby Seats And Minis
10 replies to this topic
#1 stocky
stocky
  • 338 posts
Posted 06 June 2012 - 10:00 PM
as the title says, My daughter is nearly grown out of her baby seat so will need to fit a forward facing seat in the back. I have a seat that fits using inertia reel seatbelts but the mini doesnt have those
Does anyone have any ideas on how I could go about fitting this seat?
I cant fit the seat in the front as the bucket seats are too small
Thanks for any help
#2 charie t
charie t
  • 3,153 posts
Posted 06 June 2012 - 10:11 PM
grab a set of mpi seat belts matey
#3 minimaxie
minimaxie
  • 1,687 posts
Posted 06 June 2012 - 10:14 PM
2nd that, speak to dale (R1minimagic) hes got loads of MPi spares :)
#4 clubman wayne
clubman wayne
  • 66 posts
  • Local Club: robin hood
Posted 06 June 2012 - 10:16 PM
i had a escort cabriolet with lap belts on the rear seat and at the time halfords did a seat just for the old lap belts
#5 stocky
stocky
  • 338 posts
Posted 06 June 2012 - 10:21 PM
I already have a seat just wanted to know how I would go about fitting the bealts. So Mpi seatbelts? where would they fit? I should add at this point as charlie t knows, I have a rollcage
#6 coopersmate
coopersmate
  • 408 posts
Posted 07 June 2012 - 07:42 AM
I have this problem but solved it by having the buckel shortened to stop buckle crunch, I then just adjusted the static belt until it was tight and the seat didn't move. A pain in the bum to do but once done and you never adjust the belt again it is done. My kids seats do require me sat on them to get the buckels all done up nice and tight.
I have also done the same with the next stage seat (booster seat and built in back for my 3 year old). All seems fine
#7 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,144 posts
  • Name: Sean
Posted 07 June 2012 - 08:43 AM
You can fit the seats using the static belts. I've seen that done in mates cars and they were secure.
He used a recarro one and that was fine, I know at least one other person who's used one.
You do need one with a small base though.
I've got a Lap strap seat for my estate, a britax jet eclipse and that fits fine
The rollcage thing may be an issue though and thats entirely your call.
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 07 June 2012 - 09:23 AM
You need to make sure there is no risk of the child injuring themselves on the cage
#9 frog998
frog998
  • 595 posts
Posted 07 June 2012 - 04:01 PM
I use the standard static belts in the back to hold both my sons stage 2 seat (the belt only holds the seat and then the seat has its own harness) and the daughter happily sits in a high back booster using the static belt.
As long as the belts are adjusted correctly i dont see any issues
#10 cal844
cal844
  • 9,630 posts
  • Local Club: TFMOC
Posted 07 June 2012 - 05:28 PM
securon 254... diy fit as they bolt straight in :)
#11 Midas Mk1
Midas Mk1
  • 5,782 posts
  • Local Club: S.U.N.M.C
Posted 07 June 2012 - 05:56 PM
Mpi rear belts dont fit without mods, they're 4 point rather 3 point.
